Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-22-2007, 10:23 PM
Leadhead Leadhead is offline
'98 Cummins, won't downshift to 1st
A few weeks ago I bought this '98 automatic. I love the truck, but an annoying problem keeps popping up. The truck normally shifts fine, but once in a while it will not shift into 1st gear at a stop. If I manually kick it down to 1st it will usually cooperate and upshift ok, but typically the symptom continues at least until I shut off the truck and start it again. Other times even if I put it in 1st gear it still refuses to shift lower than 2nd. Tonight coming home from work it kept starting out in 3rd gear! If I shifted down manually it would go to 2nd, but not 1st.
This problem might occur a couple days in a row, or it might work fine for 3 or 4 days. Is my tranny on the way out or is there a likely fix that won't cost me a couple grand?
Old 05-25-2007, 08:25 AM
moparman1994's Avatar
moparman1994 moparman1994 is offline
Re: '98 Cummins, won't downshift to 1st
Go to dieselbombers.com and join and start asking questions they will know because theres dodge gmcs chevys ford and others but they will know.
Old 05-25-2007, 03:45 PM
Thanks for the information; I'll check it out.
Old 08-10-2007, 04:41 PM
Lbrist Lbrist is offline
My 97 does the same thing, I just changed the speed sensor but it didn't fix that problem, maybe a shift solinoid?
