Old 05-22-2007, 08:05 PM
lidation lidation is offline
A/C can't turn off?
I found out that my A/C can't be turned off. I assume that A/C should only be on when you turn the switch to "AC" or "Max AC" in the temperature control panel right?
When that switch on my '98 3.8l is not on either of the AC or Max AC, but on for example, floor vent, and if I dial the temperature all the way to the coldest, then the A/C is on.
Is this only on my car or Ford makes it that way?
Old 05-22-2007, 08:53 PM
RickMN RickMN is offline
Re: A/C can't turn off?
A/C is also on in the defrost mode, unless the outside temp is below freezing. It should be off in all heater modes.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
Old 05-23-2007, 07:30 AM
Mama's T-Bird Mama's T-Bird is offline
Send a message via Yahoo to Mama's T-Bird
If my dial is on one of the heat-modes only, and the temperature dial is set all the way to cold (blue), then my air-conditioner comes on too.
Old 05-23-2007, 08:45 PM
wiswind wiswind is offline
My '96 has the A/C active in all positions except the dashboard VENT and the OFF positions.....
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
