Old 05-22-2007, 04:24 PM
Senior07 Senior07 is offline
New Tires 99 Silverado
Will 285-75-16 tires fit on the factory rims, or will they rub the wheel well when I turn?
Old 05-22-2007, 06:49 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: New Tires 99 Silverado
IIRC those will rub
I am running 265 75 r16's... I like those a lot.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 05-22-2007, 07:54 PM
rjeffery rjeffery is offline
285/75/16 should fit on 4wd trucks. 265/75/16 is the largest you can go on 2wds.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 05-22-2007, 08:54 PM
I don't see what difference 2wd vs 4wdmakes... ride height is the same. That is, unless you crank the torsion bar on a 4wd, but that's another mod altogether.
Old 05-22-2007, 09:53 PM
The front end of a 4wd sits higher.
Old 05-23-2007, 06:43 PM
Not in the 99-up, absolutely not. I've pulled nose to nose to a stock 01 Z71 and there wasn't a 1/2" worth of difference, and our tires may have been different sizes or different pressures.
Old 05-24-2007, 09:04 AM
ylikebeef ylikebeef is offline
wouldn't the offset of the rims make a difference? Since 285 is a wider tire, I would guess that the offest of the rim would play an important factor on the difference between 2wd and 4wd.
Oh, i have 285/35/22's on my truck with 22x10 inch rims....it rubs pretty bad when I turn. My turning radius as been reduced to almost nothing.
Old 05-24-2007, 09:24 AM
I did some research last night and came up with this. 285's are only 20mm wider, 10 on each side. I jacked up the front end of the truck and cranked the wheel all the way in both directions and have about an inch and a half clearance. Then I dropped it down and did the same. Only about 1/2 inch of clearance at normal ride hight. I think as long as you don't turn the wheel all the way in either direction it shouldn't be a problem.
Old 05-24-2007, 11:05 AM
masapell's Avatar
masapell masapell is offline
I guess as long as you remember that EVERY time you have to make a tight turn!
Sincerely,
Matt
2014 Ram 1500 Crew Cab
