Old 05-22-2007, 01:51 PM
barker23 barker23 is offline
Send a message via Yahoo to barker23
94 C1500 4.3 sensor wiring ?
I just recently put a different engine in my truck, same tranny and intake tho. I have ended up with a couple connectors that I cant seem to locate the sensor for. Im getting fuel to the intake, but nothing from the injectors and Im not sure if these connectors have something to do with it. Any help would be appreciated.
1st connector: Marked PED 15 on a Red and Blue connector with 1 Green wire and 1 Black wire.
Located on right side of engine behind the A/C drive.
2nd connector: Marked PED 21 on a Black and Blue connector with 1 Blue wire and 1 Purple wire.
Located on right side of engine next to the intake.
3rd connector: Marked PED 2 on a Blue and Black connector with 1 Green wire only.
Located on left side of engine by the exhaust manifold and tied in with a knock sensor.
03 Chevy Trailblazer LT EXT
04 Silverado Z71
88 Fiero Formula V-6
82 Chevy Corvette
07 Dodge Caliber
Old 05-22-2007, 03:29 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 94 C1500 4.3 sensor wiring ?
If you still have it, check the old engine and see if there are sensors where there aren't on the new one. Also if the terminals inside the connectors are old looking and corroded, there's a good chance they weren't connected to anything to begin with. I've had several cars some in my shop that have a connector or two off with nothing that they'll even reach.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 05-22-2007, 04:02 PM
Unfortunately I do not have the old block, this has been a on going project and frankly quite a pain in the #@$. It has taken me 3 engines so far to get one that would work and crank over.
I did check for corrosion on the connectors and they all seem to look like they were connected at one time.
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
