Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 05-22-2007, 11:16 AM
stevedad25 stevedad25 is offline
'02 Cruiser front end clunk
Hey everyone.
I need some help diagnosing a front end clunk. It occurs on the passenger side when going over bumps. The CV boots look fine and the bearings were packed recently and seem to be OK. I had the sway bar on the drivers side replaced a year ago. Could the passenger side bar be the culprit? Thanks
Old 11-27-2007, 01:26 AM
yale329 yale329 is offline
Re: '02 Cruiser front end clunk
is it possible it's a worn bushing for there are many,tie rod, ball joint or a worn out strut. If your at a lower milage, I would suspect a strut, or strut bearing first.
Old 11-28-2007, 02:31 PM
santacruzr santacruzr is offline
sounds like a broken lower motor mount, mine had the same symptom
Old 11-28-2007, 05:59 PM
Thumbs up Re: '02 Cruiser front end clunk
I'm scared to tell you now. Read my POST. good luck friend.
Old 11-29-2007, 08:18 PM
wayneo69 wayneo69 is offline
pt's and neons are know for lower control arm bushings and lower motor mounts
Old 11-30-2007, 08:47 PM
wow i almost forgot my parts guy was complaining of a simular noise i put it on the lift and found a bad outer tie rod i was surprised because normaly it is bad lower control arm bushings but that was the only time i had that problem with a cruiser
Old 12-30-2007, 12:43 AM
rtart rtart is offline
Check your swaybar bushings to frame. After replacing struts,bearings,tierods,controlarms(with bushings and ball joints) and a motormount i still had a clunk. I suspected the swaybar afterall everything had been replaced. So I just completely removed the swaybar from the car and took it for a test drive. The noise was gone. Also when i took off the swaybar off, I inspected the parts and i found that the the bushings on the swaybar (where they connect to the frame) were bad. It turns out that the bushing are hard and not very rubber like causing a clunk in the front end. So if you have rulled out every thing else you might want to try this.
