Old 05-22-2007, 10:23 AM
4xbill 4xbill is offline
Noise from rear end
I have a 2000 Silverado Z71. Over the past year I've noticed a "whoop" noise from the rear end when I start from a dead stop. I recently had a suspension lift added to the truck and now the noise seems more pronounced. Has anyone else run across this issue?
Old 05-22-2007, 11:52 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Noise from rear end
Sounds to me like the typical slip yolk clunk and by putting in a lift, you have increased the driveline angle and that is why it seems more pronounced now.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 05-22-2007, 01:18 PM
Thanks Kenny, it's not a clunk though, it's a "whoop". Would the slip yolk create that noise as well?
Old 05-22-2007, 08:14 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I think I may know what you're talking about. Is there any way you can give a more detailed description of the sound and/or feel.
*Under Construction - New sig to debut*
Old 05-23-2007, 07:56 AM
There's no feel to it all, no bump or jerk or anything like like that. It's just the whooping sound. It's almost like the sound of an owl, just not as long as an owl "who" would be. This is really hard to explain in words.
Old 05-28-2007, 01:21 AM
WalrusInc WalrusInc is offline
This job would be no fun without getting to listen to customers make noises and then having them repeat it. ><
Old 05-28-2007, 01:57 PM
bigbadram51 bigbadram51 is offline
Could be axle wrap. How big of a lift did you add. If it was 6" and you used like a 5 1/2inch block with the factory two inch block, that is normally enough leverage to twist the axle and thats the sound you hear. Best way to tell is to leave it in park, have a buddy grab the tire and try to spin it. You get down behind the pickup and see if the axle slips around the block. The only fixes are to get traction bars. All new leaf springs, or shorter blocks and use an add-a-leaf
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 05-29-2007, 08:10 AM
Thanks Bigbad but the noise was happening before I lifted the truck as well so I don't think it's axle wrap.
Old 05-29-2007, 11:40 PM
I was just thinking about my Silvy and I had a "hoo" kind of sound in my rear end and never thought much of it, and it didnt do it all the time. But since I re-geared and ditched the factory locker for a Auburn limited slip, I havent heard anything. But who knows
3" PA Body Lift
Covermaster Top
Old 05-30-2007, 08:02 AM
Well, I did some searching in the posts here and found a possible solution my problem. I've read that I can stick a racquetball in the yoke and that will fix it. Thanks to all for their input.
Old 05-30-2007, 09:21 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Here is a sight that may help you figure out the noise.
http://www.differentials.com/install.html
Good Luck
MT
MT
