Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 05-22-2007, 06:08 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
rebuild help! (sorta)
ok. ive decided. im gonna pull the engine and work on it.. eithier the LT1 or the TPi.. im leaning towards the TPI just cuz i dont have to have a broken car (not working till i finish the engine sorta thing) the TPi will bolt up to the t-56, right? anyway, i wanted a manual for both the TPI and the LT1.. .anyone got any good rebuild manual suggestions? i perfer a lot of pictures..cuiz im a visual learner. i really do need to learn about the details of engine working and i figure, hell, lets go for it.
this is gonna be a loooong rebuild tho, so thats why i wanna do it on the TPI from my broken firebird...
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 05-22-2007, 08:47 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: rebuild help! (sorta)
Don't be so intimidated.
Take your time, label things correctly so they don't get crossed. Mainly vacuum connections. Wouldn't hurt to do the electrical connections, but most snesor connectors only connect one way to a secific sensor.
When it comes down to removing parts from the motor, printer paper box tops are god. IE -cylinder heads, make a diagram of the head on the the box top and direction of the motor, always use forward as a point of ref. Then as you remove each bolt, take a screwdirver and pop a hole in the box top in relation to where it came off the head, same would apply to almost everything else, intake, water pump, oil pan, headers, etc.
Really, once all the wiring and hoses is out of the way, the actual rebuilding process of the motor is fairly easy believe it or not.
Although I understand your reasoning, I think back tracking to a TPI from the LT1 is not a good idea. I would be more concerned of engine management by the ECM more than a rebuild going that route.
Old 05-22-2007, 11:39 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
i cant let you RUIN A SS!!!!, build the lt1!!!!
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
