Old 05-22-2007, 12:59 AM
Zurbert82's Avatar
Zurbert82 Zurbert82 is offline
Revell Sauber BMW F1.06
Here is my current build. I was disappointed with the amount of flash in comparison to Revell's previous F1 kits, but a little but of cleanup goes a long way. I know there is a current thread on the same kit so don't mind me
I've assembled the bulk of the chassis using filler around the sidepods where the air intakes are, and also the monococque around the front suspension as Revell have moulded this piece to be glued after the suspension is in place. This is typical of most if not all Revell F1 kits, but once primed it hopefully shouldn't be noticable.
Some of the diffuser parts have very odd joins with the undertray, more filler was needed here. This kit is going to need a lot of it!
More to come.
Old 05-22-2007, 02:06 AM
billypee's Avatar
billypee billypee is offline
Send a message via AIM to billypee
Re: Revell Sauber BMW F1.06
Nice start. Make sure you test the fitment of all the parts with the Revell F1 kits.
Kind regards,
Bill
On the workbench:
Completed WIPs:
Completed Models Gallery:
Old 05-23-2007, 05:04 AM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Good start, keep the updates coming!
Old 06-28-2007, 08:07 PM
Zurbert82's Avatar
I have finally stopped slacking and picked up some progress on this kit. I have since sprayed the body and all body components Tamiya Pure White, then masked off the body for Tamiya Mica Blue. I dont know if it is correct, but it's the same color used on my Sauber C22. I made an error masking the blue on the rear kickups, which forced me to move the Petronas and Red pinstriping decals back, but it's not bad. The undertray is fairly simple, but the included carbon fiber decals make it 10 times better. As you can see, the brakes are pretty simple as well, but this will all be hidden once the wheels are mounted.
Old 06-29-2007, 02:03 AM
billypee's Avatar
The model looks excellent in this update. As for the blue, it looks correct to me (and it is always difficult to judge from photographs). Don't forget to paint the inside of the monocoque
All the very best,
Bill
On the workbench:
Completed WIPs:
Old 06-29-2007, 04:48 AM
stevenoble's Avatar
Nice work.The blue looks fine.Great paint job.
Steve Noble
Old 07-04-2007, 07:28 PM
RunFlat's Avatar
RunFlat RunFlat is offline
How did you install the front suspension with the bodywork being finished?
Old 07-05-2007, 02:05 PM
Zurbert82's Avatar
I cut the upper wishbone in half and trimmed some the excess material off. It fits perfectly in to the finished monococque with no glue. In fact all the front suspension pieces are not glued.
Old 07-05-2007, 04:20 PM
RunFlat's Avatar
Slick move!
I just started on mine and I'll put that tip to good use. Thanks!
