Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-21-2007, 09:00 PM
mikeld05 mikeld05 is offline
Angry Bad Ignition Coils?
Bonnieville Sse has starting performance. While the car does start it some times takes time to crank when cold. When slightly warmed the car act like it has turned over then losses power and then cranks , so i have to old the key longer. Im assuming this is because of the coils because i have put new air filters,spark plugs,PCV valve,ingition wires,02 senser,injectors clean,oil change,simi new battery
Old 05-22-2007, 06:34 PM
jdq jdq is offline
Re: Bad Ignition Coils?
Try taking an ohm meter and place probes on each of the 2 coil terminals .They should all be close in range between 5 and 8 ohms.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 05-22-2007, 08:02 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Check the fuel pressure. If the fuel pressure regulator is going bad you can get a poor starting condition especially when the engine is warm. Should be in the 45 to 55 pound range. If it is less then the regulator or the fuel pump could be going bad.
Old 05-23-2007, 08:13 AM
Yeah im going to get the fuel pressure checked today along with the coils to see whats going on. Thanks for the suggestions ill let you know what i find
