Go Back   Automotive Forums Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 05-21-2007, 08:22 PM
superslug1987 superslug1987 is offline
new GTE won't boost
I'm toward the end of a GE-GTE swap and I've run into a problem. I got it to run good naturally, but when I plumbed up the turbo I have no boost. I routed all my intercooler piping and clamped it all(it's not leaking) I'm running a Blitz BOV, and I think my wastegate is sealed, yet I still show -19 on my boost/vac. If I hit high rpm and back out, it pushes just under 1 psi and I hear a faint noise from the BOV. I'm not sure if I have my boost controller hooked up incorrectly. The engine still runs great, no spitting or misfire, just no boost. My turbo is spinning, and while I ran it naturally I could see the impellar spinning normally. Any help would be appreciated.
Old 05-21-2007, 10:40 PM
flyinMKIV's Avatar
flyinMKIV flyinMKIV is offline
AF - Advisor
Send a message via AIM to flyinMKIV
Re: new GTE won't boost
it would be nice to know what year of a car we are dealing with. but just a thought
02 Honda Accord (Sold)
93.5 Supra non-turbo (Sold)
94 Lexus GS300: 2jzgte swapped (sold)
08 Scion TC (daily driver)
94 Supra Single Turbo (Sold)
97 Top Secret Widebody Supra Turbo (Work in progress)
If your talking trash, I'll be showing my ass
http://www.automotiveforums.com/vbul...d.php?t=535850
http://www.automotiveforums.com/vbul...d.php?t=212356
Old 05-22-2007, 12:14 AM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
First, double check to make sure the intake and boost gauge aren't leaking. Then have a look at the waste gate controller. "I think I did xxx right" is usually a good indicator that something may not have been done right.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 05-23-2007, 01:07 PM
The car is an 87, the engine is an 88-89, the turbo is an 88, the computer/wiring harness is an 89. I hooked the feed line of the boost controller to the intake, and the side that said "to wastegate" to the wastegate actuator. In a moment of desperation, I disconnected the lines and plugged them so the wastegate would stay sealed. I took the turbo back down today, and the wastegate is sealing. I ran it with the outlet off to make sure. I tried bypassing the intercooler and it didn't work. I still get full vacuum. I crawled under the car and checked for leaks and found none. I disconnected the pipe at the BOV and held my hand over it while it was running ( took a lot of effort to get it to run w/o the MAF) Once I got it hot I was able to (carefully) rev the engine to about 4500 and the turbo was unable to push my hand off the pipe. Do I have a defective turbo? The intake gaskets are new and I checked them for leaks with an automotive stethoscope. Boost gauge is good, I used it as a vac gauge for months and never had any problems. I'm going to pull the turbo out again when it cools off and see if I can find anything wrong. I'm new to turbos and I do have one dumb question... If I go to buy an aftermarket turbo, what flanges do I have/need? Is the manifold flange a T4? What will work... cheap?
Old 05-28-2007, 07:56 AM
silversup silversup is offline
Pull the pipe off your turbo and see if u see the impeller or whatever turning when u rev it.
Depends on which turbo u buy. Some are bolt on, others like t4 need adapter or manifold not to mention downpipe
Old 06-12-2007, 10:28 PM
badboybubby badboybubby is offline
Have you tried making a plug and using an air compressor to presurise the intake and check for leaks ?
