Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-21-2007, 05:36 PM
geardriven74 geardriven74 is offline
93 Trans-am voltage problem
A friend of mine has a 93 Trans-am that has a voltage drop problem. Voltage drops below 12 when the car is warm and the ac is turned on at idle. He had a 108 amp alt. from autozone on the car. We found the correct 124 amp. alt. but the car still has the same problem. I'm wondering if the cooling fans are creating a short. Anyone had a similar problem or got any ideas?
Thanks for your time.
Old 05-22-2007, 12:10 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 93 Trans-am voltage problem
I had that same problem with my 92 and all it ended up being was a bad altenator... Your pully belt has enough tension in it, right? Sometimes if they are loose or worn out it could cause a problem. Donno what the odds are, but I've seen it...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-22-2007, 07:29 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
its the LT with the sidecaps also right? remove the bolt from the plastic sleeve, take the sleeve off. on my sisters 97 and my 97, the sleeve was hiding the major corrosion on the wire. cleaning it off made my sisters car work! that simple :/ that is, if it isnt the tension..etc
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 05-22-2007, 10:29 AM
rather_b_boatin rather_b_boatin is offline
Does the voltage go above 12v when you rev it with all the accesories going?
