Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 05-21-2007, 01:36 PM
93SHOcarguy 93SHOcarguy is offline
95 Suburban Dies
I recently purchased a 95 K1500 Suburban with 210,000 miles. The truck looks and seems to run great. The other day I took it on a couple hundred mile round trip with the family. We ran the AC the whole way. When I exited the interstate, the truck died. I coasted to a stop, opened the hood, saw nothing strange, started the truck and drove home, at 2 other stops before I got there, it died again. When I started it, the truck spat and sputtered, and eventually came back to life. I had no more problems until Friday when I went out of town again and the truck did exactly the same thing.
Just as preventative maintenance, the plugs, wires, and thermostat have been replaced as well as the radiator flushed. I have no problems when I just drive around town for the day, the issue seems to be when I drive some distance. The AC being on doesn't appear to have any affect.
Any help would be great. I'm hoping it's something simple because now my wife is afraid to go out of town with me in the Suburban (maybe this isn't such a bad problem after all...LOL)
I forgot to mention that there are no codes present. Service engine light is not on.
Old 06-16-2007, 06:08 PM
Fryall4 Fryall4 is offline
Re: 95 Suburban Dies
Hey 93 SHO, this seems to be an epidemic, my 93 is doing the same thing. I have tried a lot of parts and have yet to find the cause of my headache. My truck is currently in the shop and I do not plan on picking it up till it is fixed. My truck runs perfect off idle, so it is hard to think it may be a terminal issue for the beast. I have to date replaced;
fuel filter,
cap, rotor, plugs, wires
IAC valve
TCC Solenoid
Ignition coil
Pick up coil
ignition control module
I've also checked for vaccum leaks, removed the throttle body and cleaned, checked timing, blah blah blah, everything there is to check. With a '95 I would suggest checking the fuel pressure, there should be a Shrader valve on the fuel rail to attach a guage to. I am not too familiar with the 95's so someone more knowledeable can help with the particulars. Fry-
Old 06-16-2007, 06:14 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Have you done a cold and hot fuel pressure test on it? Sounds like the problem is somewhere in here. Possibly a dirty fuel filter, maybe fuel pressure regulator, maybe a pump on the wane.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-18-2007, 09:13 AM
TampaRob TampaRob is offline
I just had the same problem with my 97 Suburban. Turns out it was the fuel pump. You'll probably notice that the problem will get worse as the week goes on. Listen to see if you can hear the fuel pump come on when you turn the key on. It will come on for a few seconds everytime you turn the key on.
Hope that helps a little.
Rob
