Old 05-21-2007, 12:38 PM
eli1969 eli1969 is offline
perfomance increase question
Alright, my chevy lacks the performance that I desire so I put in an RV cam and some new lifters oh yea I just had my tranny rebuilt and she runs great. My question to you all wise performance seeking folks is this, will a high rise manifold increase performance along with the RV cam or will it make little noticable difference? Would like to know the answere or if anyone has some great performance techniques for my 92 chevy 3/4 ton extended cab RV pulling machine.
Old 05-21-2007, 02:01 PM
mr_mushroom's Avatar
mr_mushroom mr_mushroom is offline
Send a message via AIM to mr_mushroom
Re: perfomance increase question
the real key when you're going for performance is to get things that match the RPM range of where your power is.
you want the power where you drive it most.
so about that high-rise intake manifold:
there are a few different models, but most of them produce power at higher RPMs. usually their 'powerband' is in the 1,500 to 6,500 rpm range.
being that you're towing an rv(?) i guess, it might be better to get like a torker cam and manifold to increase your low-end power, as high-rise manifolds are generally designed to help with horsepower, at some cost to torque.
especially towing.
just remember that torque gets you going, and horsepower keeps you fast.
and always always match your components.
don't get a cam that puts all your power at 2K and a manifold that works best at 5K and a 3K stall speed.
yes, you'll go faster than stock, but not as fast as if you matched your components a little better.
plus make sure that your tranny will handle whatever you throw at it.
don't go building a 450hp beast with a 700r4.
good luck!
all your are belong to us.
Old 05-22-2007, 09:11 AM
Thanks for the reply, I will check into the manifold matching the cam and see if it will work. And yes I pull an RV 22 footer and snowmachine trailer most of the time so that is where I want the power to be at, torque not just speed.
Thanks
