Old 05-21-2007, 09:36 AM
S10SNODOG's Avatar
S10SNODOG S10SNODOG is offline
Fuel Filter replace
If I replace the fuel filter will fuel spill out when i take old one out ? do I have to have a empty tank or bucket to catch feul ? Thank You ! 2003 s-10 crew cab
Old 05-21-2007, 04:10 PM
duke350 duke350 is offline
Re: Fuel Filter replace
A bit will come out, especially if you have recently had it started or the key on to pressurize the system. There really isn't to much to come out, just what may be in the line and the filter itself. A "catch can" of some type will let you catch most of it, or a good absorbent rag wrapped near the end(s) of the filter when you remove the line.
Old 05-21-2007, 07:43 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Definately wear eye protection while doing this to be on the safe side. use a pan or something under the filter to catch any fuel. Some fuel will come out but not too much and no, you don't need to drain your fuel tank. Just loosen the fuel line and pop the clip on the filter and it should slide out. To make it a little easier, you can pop the fuel lines from the clips on top of the filter and remove the bolt behind the filter and remove the whole bracket.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
