Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-21-2007, 09:00 AM
ThiRteeN's Avatar
ThiRteeN ThiRteeN is offline
Send a message via AIM to ThiRteeN
Auto tranny clutch problems
When I come to a stop, the auto clutch musn't disengage completely because my car will vibrate a little bit and idle really low. When i put it in neutral, it idles just fine. What do I do? I am thinking about an auto to manual swap.
Definition of Ultimate Rejection:
-When your hand falls asleep while jerking off
-98 Civic DX....R.I.P.
-96 HX...........work in progress
Old 05-21-2007, 01:24 PM
jclark jclark is offline
Re: Auto tranny clutch problems
It may or may not be your transmission.
It quits in neutral because there's no load on the engine.
A simple vacuum leak can do that.
You need to check out your engine, I'll bet it's there.
Jim C.
Old 05-21-2007, 06:51 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
i agree on the auto to manual swap... i also agree that you tranny isnt your problem.. when was your last tune up? ill bet a tune up and some seafoam and that engine will run like new
Old 05-23-2007, 12:48 PM
ThiRteeN's Avatar
and a normal tune up costs about......? $50? more?
Old 05-23-2007, 02:02 PM
Kind of a Big Deal
depends... you can half ass one and only do, plugs, wires and oil change for like 50.. or you can do a REAL tune up and do plugs, wires, cap, rotor, fuel filter, air filter, PCV Valve and oil change.
Old 05-23-2007, 09:51 PM
ThiRteeN's Avatar
aahhh...cause i've changed the oil and plugs, but i guess I'm gunna go all out.......when I get more cash. Just bought 17" Motegi rims today, sent me a grand in the hole
Old 05-24-2007, 11:33 AM
Kind of a Big Deal
hmm.. rims.... or make my car run better... and you chose rims?
Old 05-24-2007, 09:36 PM
ThiRteeN's Avatar
It's because i was rolling on 2 18s and 2 steelies, so id rather have a better ride and gas milage having all four same sized rims. I should be getting the tune up next pay check, so, next friday
Old 05-25-2007, 08:33 AM
Kind of a Big Deal
ok, but wouldnt be cheaper to get two more steelies? then youd have a better ride and better gas mileage... and still be able to do a tune up... but whatever, its your car.
