two things
The weather strip on the rear side door by the wheel well is coming off. What can I use to glue it back so It won't come off again? Also, Is the rear cargo door glass really glass or is it a thick plastic? The reason that I ask that is because I want to use a light compound polish to get the waterspots off and I think that would scratch plastic.
Re: two things
Use 3m double stick foam tape for the trim amd yes its a glass hatch on my 02 tb
2002 LT Trailblazer 4x4 One of the first of this kind on the road 2003 3500 LT Silverado 4x4 ext cab 2006 Heritage Softail HD FLSTI |
Re: two things
the foam tape MIGHT work, but I repaired mine on both sides with #M Black Weatherstrip Adhesive. Just make sure you clean the inside groove of the weatherstrip rreally good, a lot of dirt and debris had gathered in mine. Also, clean off the metal edge where the weatherstrip fits on. then just run a thin bead of adhesive on the metal or down in the rubber grrove, slide the weatherstrip back on, and keep on 'blazin'!
