All of a sudden the windows and sunroof wont work. I checked the fuses they are fine and everything else works. Can anyone help?
Re: Power windows and sunroof
Welcome to the forum! What year is your Mountaineer?
Depending on the year, did you check the accessory delay relay in the relay module under the dash or for power to the window switch? -Rod |
It is a 2000
Okay, I happened to be looking at the wiring diagram for a 2000 when I typed my previous reply, so I still suggest checking the accessory delay relay. If you don't want to open the relay module, then it may be easier for you to check for power to the window switch panel.
If you are comfortable with a multimeter and wiring and would like a copy of the wiring diagram for your power windows, send me a private message wtih an e-mail address for you that can accept PDF attachments and I'll send the wiring diagrams to you. -Rod |
