Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-21-2007, 07:13 AM
tattoou tattoou is offline
92 Eclipse Dies whenever it wants ?
This car will run like a champ for about 20 miles or 20 minutes then die, even while going 70 MPH it just dies, I checked and had spark and 55 LBS fuel pressure at the rail when it died tonight but it wont start for around 15 minutes ? Does the ECM control the injectors ? Thats the only thing I can think could be wrong ?
Old 05-21-2007, 07:52 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 92 Eclipse Dies whenever it wants ?
Pull the ECU and check the caps.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-21-2007, 10:03 AM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
my old GS did this, it ended up being a senser...a heat senser i beleive!!
Old 05-22-2007, 02:36 AM
I have a ECU coming from E-bay,
Old 05-22-2007, 02:59 AM
I have a data log if anyone would like to see it.
Old 05-22-2007, 08:03 AM
I didn't mean that you had to go out and buy one, I just wanted you to see if the caps were leaking.
1997 Spyder GS-T
5-Speed
Old 05-22-2007, 08:04 AM
Spyderturbo, I see your logger, Is there a reading for KNCK, is this knock sensor ? mine is always 0.
Old 05-22-2007, 08:05 AM
I got it for 40 bucks for a backup been waiting for it for a while
Old 05-22-2007, 10:49 AM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
my 1g used to do this and it ended up being the Idel speed control sensor.
Old 05-22-2007, 10:55 AM
Unfortunately, the 2g's don't output knock count to the OBD-II port. You 1g guys are luck since you can see all the really important parameters like IDC, Knock, etc. All of us 2g guys have to rely on timing and airflow numbers.
Anyway, BoyertownMidnight is correct, a speed sensor can cause the same problems, but that normally only happens when the car comes to a stop. Either way, also another good thing to check.
1997 Spyder GS-T
5-Speed
Old 05-22-2007, 11:23 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
When the car dies and you try to start it again, do you hear the fuel pump kicking in???
This happened to my mom's Grand Caravan... turned out the fuel pump burned out... we could drive the car for 15-20 min, then the damn pump would overheat and stop working... give it 30-60 mins and it would work again...
It eventually had to be replaced...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 05-22-2007, 11:32 AM
I have 55 lbs to the fuel rail and spark on all 4 plugs, you wait then here a click under the dash after about 10 min. and it will start.
Old 05-22-2007, 11:37 AM
Mikelb's Avatar
sounds like the ECU or some sort of relay...
Seriously, even after you get the other one in hand, pull that ECU and take a look at its guts... see if there's any problems in there...
Old 05-22-2007, 11:39 AM
I will probably rebuild it and add a power chip and new caps.
Old 05-22-2007, 05:04 PM
I opened up the ECU, the little board that is standing up, has E538 on it. Is in bad shape. I dont see the caps ?
