Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 05-20-2007, 10:29 PM
jhoffman jhoffman is offline
99 Sebring won't start
My daughter went into a store and when she came out her car wouldn't start. It turns over but won't start. It has no spark. We replaced the distributor, still wouldn't start. Then we replaced the engine computer still nothing ( it is the right computer, I matched the numbers up). Then we replaced the crank position sensor, still no start or no spark. Going crazy here. What else could it be? We also checked all the fuses and fusible links, all look good.
Old 05-25-2007, 06:11 PM
twistedtech twistedtech is offline
Re: 99 Sebring won't start
What motor?
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 05-25-2007, 10:52 PM
It has the 6 cylinder 2.5 liter
Old 09-11-2007, 08:47 AM
sunniebeech sunniebeech is offline
Did anyone figure this out? I'm going through the same thing. Thanks.
Old 09-19-2007, 11:34 PM
alcandoit4u alcandoit4u is offline
I have been going through the same thing. i just replaced the distributer and it didnt help at all
did you get it fixed?
Old 09-20-2007, 04:23 PM
It appears to be fixed! The last 2 items replaced were the distributor and the crankshaft sensor. Both were done at Pep Boys for just under $500. The car had gotten to the point it would not start. Hope this helps! Good luck!
Old 04-11-2008, 02:02 PM
cantfixit2 cantfixit2 is offline
I have the same problem. Driving down the highway one morning and it starts to skip and hesitate, RPM needle is flying all over the place, engine light comes on and eventually the battery light. It never really stalls on me but it skips to the point where it is undriveable. I have already replaced the distributor, wires, crank shaft sensor, etc. within last nine months. I also replaced, alternator, battery, and starter in the past year. I can start it but it won't stay running. Can it be the PCM? I ask because all the codes throw back to only those parts that have been recently replaced. Three different diagnostics but the codes all show the same issues. Its frustrating. Could all the same replacement parts have gone bad again? 200K miles but a nice car. Limited Edition Convertible 2.5 V6
Old 04-12-2008, 09:02 AM
Hey canfixit, I finally gave up on my Sebring. It had less than 90k miles and was in awesome "eye candy" condition but I had to have something reliable so I could get to work. I traded it because my ethics wouldn't let me sell it outright without telling the buyer what was going on. They gave me $2k for trade in...much less than it should have been worth given miles, body condition, etc. I wish you all the luck in the world getting yours going reliably! Post and let us know how it turns out, okay?
Old 04-14-2008, 07:22 AM
Thanks for the info but I am not quite ready to throw in the towel. With 200K miles probably not even good for trade. Unless I have been unfortunate enough to have gotten ALL bad after market parts from my mechanic, I think it might be the PCM. Why else would it only code the replacement parts? I'd like to try and replace it but I can't find it? Any idea of its location in the vehicle?
Old 04-14-2008, 04:48 PM
canfixit, I have the Haynes Repair Manual if you want it. Email where to send it US Mail to [email protected]. Meanwhile what year is your car and I can tell you what the manual says about the PCM.
If I remember correctly, my sebring kept throwing the same codes over and over after replacing the parts too.
I know...not helping...good luck!
Old 04-15-2008, 06:33 AM
the car is a 1999 limited edition 2.5 v6. I will let you know about the manual, thanks for the offer.
Old 05-14-2008, 12:10 PM
jeninds jeninds is offline
I have had two cars do this to me and both times it was the crank shaft/ cam shaft sensor.
