Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-20-2007, 09:39 PM
spyder9789 spyder9789 is offline
1997 Gs-T Help
Okay, this is the situation. I recently got rid of my 97 eclipse Gs for a Gst. It was an even swap so I couldn't pass it up. The car was a virgin it was babied all its life and was never modified. It had a few "small" problems. So I thought it would be a great project car. Anyways the second gear is real touchy so i bought 1 qt. of redline heavy shockproof and 2 qt. of redline mtl and maybe that will fix that. My boost would cut out at 4500 rpm. I replaced the factory intake with an aftermarket one, when i did the vacuum hose that connected the BOV to the intake didn't fit properly so we ran it without it. Now that the BOV was venting to the atmosphere the boost worked almost perfect but it idled like crap. I'm thinking about using a MAF Translator so it will idle if that'll work. But that still leaves a unfiltered hole on the intake where the hose used to be. I put tape over the hole but stopping it up made the boost cut out again and the car started jerking every now and then. So then I tried to put a cloth over it for the time being so it would still pull in air but even that messed it up so what should I do about that. The car is also running rich and gets horrible gas mileage like 15 mpg. If anyone could help me out I would greatly appreciate it.
And please no smart a** answers like sell it and buy a rear wheel drive.
Old 05-20-2007, 09:54 PM
smoke121212's Avatar
smoke121212 smoke121212 is offline
Re: 1997 Gs-T Help
first of all, welcome to the forum. Secondly, i assure you no one here is gonna tell you to sell it and buy a rwd car so dont worry about that. I cant exactly figure out your problem, if you could post a pic mabey i could get a better idea. Although without a pic you will get a lot of responses, alot of the people here know a lot more than me.
PS. please post in the correct sub-forums.
1996 eclipse gs
cold air intake, thats right im super fast now! wooooooooooooooooooooooooooooooo lol
If a man says something in the woods and there are no women around to hear him, is he still wrong?
Old 05-20-2007, 10:54 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: 1997 Gs-T Help
are you serious? You are drawing in unmetered air and you're wondering why your car is running like shit???
maybe it's your tire pressure!
now - 2000 civic
soon - 2002 is300
Old 05-20-2007, 10:58 PM
Re: 1997 Gs-T Help
lol!!!! c,mon dude give em a break. lol
1996 eclipse gs
Old 05-20-2007, 11:01 PM
Re: 1997 Gs-T Help
I know that is why the idle is out of whack, could it be running rich because it isnt getting enough air in for the air/fuel mixture. If so could a MAF Translator fix the problem?
Old 05-20-2007, 11:57 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 1997 Gs-T Help
A rear wheel drive DSM?...
I think you meant to say an AWD DSM... lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-20-2007, 11:59 PM
Re: 1997 Gs-T Help
your fuel trims are out of control. Running rich/lean, whatever, you can't diagnose it until you fix that. The ecu can do crazy things to try and correct any fuel trim errors.
It's probably a boost leak, a large one. The correct way to fix your problem is to
1. "tune" the BOV, I've described in detail how to do this before, search for it
2. plumb the BOV outlet back into the intake, if it won't fit your new intake, then put your old one back on.
3. run a boost leak test and fix the problems
The expensive and useless way is to buy a GM maf / translator (expensive) and to redo your upper intercooler pipe so that you can insert the new parts into there.
It's a no brainer...
now - 2000 civic
soon - 2002 is300
Old 05-21-2007, 12:33 PM
steviek's Avatar
steviek steviek is offline
Re: 1997 Gs-T Help
but maft lets you vent to atmosphere
oh wait he's already doing that.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-21-2007, 04:40 PM
Re: 1997 Gs-T Help
i did connect the hose from the intake to the BOV anyways even though it was hard to make it fit and it still did the same problem with the boost as it did before so that wont fix it
Old 05-21-2007, 09:10 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: 1997 Gs-T Help
you need to connect that hose or you will have this problem there is no way around it unless you buy an after market bov and tighten it down not to leak or put that tube back on...
there is no point in trying to vent unless you are going to do it right. My bov is recirculalted and its quite loud. Its a greddy type s.
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 05-22-2007, 07:12 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 1997 Gs-T Help
Alright, at least you aren't venting anymore. As for your problem, you need to explain what you mean by "cut out". What does your boost gauge tell you when that happens? Have you done a leak check? You aren't running platinum or iridium plugs are you? Do you have a way to monitor your O2 voltage? I'm asking about the front O2 because you said that your gas mileage sucked.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-22-2007, 10:19 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: 1997 Gs-T Help
Iridium plugs would work in a DSM (not ideal, but it's what I used to run)...
have you tried plugging in another MAF? your's might not be working properly
Are all of your other vacuum hoses hooked up???
When your boost "cuts out" does it feel like you hit a brick wall? (if so, look up fuel cut)
And like everyone else has said, NO Venting BOV unless you spend $$$ to do it right... Make sure that you have no nipples open, or cracked hoses, any leak in the intake will cause your car to do funny things... (look up boost leak, VFAQ has a writeup on how to make a boost leak tester)
When you get on the gas, does your car blow black smoke???(if so, refer to the comment above^, it'll be a boost leak... and that'll cause fuel cut...)
P.S.-Subforums (this should be under "Problem Diagnosis")
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 05-23-2007, 07:13 PM
Re: 1997 Gs-T Help
The check engine light did come on and it said fuel trim bank 2, how would you fix that and as for the "cutting out" with the turbo spooled at 4500 rpm it feels like hitting the brakes lightly and the gauge says that it's still spooling all the way. It also blows black smoke when shifting.
Old 05-24-2007, 02:21 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: 1997 Gs-T Help
all turbo cars blow black smoke when shifting... get a new vac line to fit the BOV to Manifold, and then for trying a new MAFT, yours is probably FU*KED! also, do the boost leak test! (its worth every second you spend doing it)
EDIT: Do it in this order:
1) Vac line from BOV to Intake Manifold
2) Boost Leak Test
*you'll probably find the problem by now*
3) New MAFT (Blow-through setup if you must insist!)
Old 05-24-2007, 12:10 PM
hicks10 hicks10 is offline
Re: 1997 Gs-T Help
ok y dont u just go to the hardware store and buy a rubber cap/plug to put over the whole on ur intake and that will take care of it idleing like shit, and u dont need to have the BOV route back into the intake it does nothing.
