Old 05-20-2007, 10:27 PM
a_alyte a_alyte is offline
Where is this noise coming from?
My '02 GT makes this grunt which can be felt from the floor board ONLY when I pull off after starting the car. Once I hear/feel this grunt, it won't happen again until I shut the car off, start it back up, then take off again. Also, it doesn't matter if I go straight, reverse or turn, once I start the car & take off, it's always there.
I just replaced the rack & pinion as well as the front driver side hub assembly. Could this be a bad rack & pinion? Should I replace the other hub assembly?
Any ideas are appreciated.
Old 05-21-2007, 03:57 PM
gtp'n gtp'n is offline
Re: Where is this noise coming from?
I have the same noise on my 2000 gtp. I was told it was the anti-lock brakes being tested after the car reaches 4 mph.
Old 05-21-2007, 04:42 PM
That's interesting. I just wasted $400 to have both front hubs replaced thinking that would solve the issue. With your GTP, can you also feel it through the floor board for a spit second?
At 20mph, I can also feel a sort of rubbing. I cannot feel it at higher speeds.
Old 05-21-2007, 05:15 PM
Ogre1 Ogre1 is offline
Yep, I have that same noise on both of my 99s
Old 05-21-2007, 06:12 PM
Ok, Thanks
Old 05-24-2007, 05:59 PM
After thinking about it, this issue started after I had the rack & pinion replaced.
Is there a particular type of rack for my '02 GT? If so, how can I find out which one I need? (Hope mechanic didn't install the wrong one)
Is it possible for the rack & pinion to cause this type of noise?
Also, the wheel is extremely easy to turn after this repair, could it be too easy?
Old 05-25-2007, 08:15 AM
troy1 troy1 is offline
AF -Advisor
My 99 has realy light steering effort also its normal. As for the buzzing its normal its the ABS unit doing a self check.
