Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-20-2007, 07:05 PM
limbo2112 limbo2112 is offline
Replacing Rear Brakes
Hi all,
I have been reading through this forum, and it is great. Very knowledgable people, and some great info.
I have a quick question. How difficult is it to replace the brake pads on a 98 2WD Rodeo? I know it has drums on the rear, correct?
I have ordered the Chilton manual for my car, because I want to start learning how to do some of this stuff on my own,...and I was wondering if I would be able to do the rear pad replacement. Initially, I thought I would be dealing with discs, but it looks like on the 2wd Rodeos, they are drums.
Thanks in advance for any tips / help.
Jim
Old 05-20-2007, 07:22 PM
surferfletch surferfletch is offline
Re: Replacing Rear Brakes
Not all 4x2s have drums. I have discs all the way around. Drums aren't hard. You just have to make sure you do one at a time or have a picture available for reference when you put it back together.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 05-20-2007, 10:20 PM
Hi Surfer,
Thanks for the reply. I'm pretty sure they are drums,...when I look in between the wheel, I can see the drum unlike the front, where I can see the rotor.
Do I need any special tools? Or does anyone have any tips / "do's" / or "don't do's" ? Thanks again
Jim
Old 05-21-2007, 03:48 PM
billindelicato's Avatar
billindelicato billindelicato is offline
if it has drum brakes and you need to replace the shoes you're gonna need a spring tool and you may as well replace the cylanders while you're down there. also when bleeding be very careful as the bleeder blolt is very delicate and will snap if you dont hit it with some pb blaster and let it sit for a while...if you snap one...good luck on finding a replacement!!! and hope to have a dealer local. everywhere i went to get replacements everyone had no idea what i needed and when they did...it was the wrong size. also make sure yours isnt set up like on the 97's with a pad shoe combo...with the ebrake being the shoes. it will look like a rotor but its more like a drum with rotor like features.
1998 Chevy Blazer LS 4x4
1996 Ford Dunderbird LX 3.8L
Old 05-21-2007, 04:56 PM
Ouch....that sounds a little intimidating.....The term "bleeding" that you are using, is that when you back off the shoes from the drum in order to remove it? Or does it have to do with the ABS at all?
Most of the manuals cut off at the 1997, and there is another manual for the 98-02. I think, from what I have read, the '98 has a standard drum system in the back.
The spring tool shouldn't be a problem.
To think,.....I thought it would just be: Remove the old ones, slap on the new ones...It's sounding more and more complicated. I was hoping not to have to take it in and save a little money, plus start a new learning adventure
Jim
Old 05-21-2007, 05:11 PM
Bleding the brakes refers to the process of getting old brake fluid out of the brake lines and new fluid in.
Old 05-24-2007, 02:08 PM
Robs97KingCabPU Robs97KingCabPU is offline
Wow, did not know that. How did you end up w/ 4-wheel discs?
"I'll feed their greed with my need for speed"
Old 05-24-2007, 03:11 PM
Ramblin Fever Ramblin Fever is offline
I have 4-wheel discs too; on my '97 4x2
However, in my vin number it states that mine was to be a 4x4 - go figure!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-24-2007, 03:23 PM
Scrapper Scrapper is offline
AF Premium User
don't forget to put a little grease on backing plate where the shoes hit..good luck..
Old 05-24-2007, 04:08 PM
Hmmm... Surfertech's is also a '97. Did they stop putting rear disks on after '97? Also, can these be retrofitted to my '01? Probably would not be worth the cost, but was just curious.
