Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '83 - '90
Old 05-20-2007, 06:39 PM
mn454 mn454 is offline
90 Fuel pump gone bad
I have a 90 jetta and the external fuel pump is not working. Is there any way that this things be made to work again? I have checked price and its about 250 $, that alot of money for a fuel pump. Has anybody tried to make them work? Any parts stores have better prices?
Old 05-21-2007, 12:03 PM
jammyjim jammyjim is offline
Re: 90 Fuel pump gone bad
Ecology. You might want to check your fuse box first. My gli kept blowing a fuse. It turned out to be the O2 censor shorting out on the exhast manifold. It is pretty easy to test your pump. Just pull it and attach it to a 12v power supply. What? YOu don't have a 12v power supply. Easy, find old computer, remove power supply, attach aligator clips to 12v output leads. You now have a switched 12v/5v power supply.
Good luck
Old 05-21-2007, 02:43 PM
Doug Tatham Doug Tatham is offline
Be very careful if you test it this way. Hook the clips up first before you turn on the power. It doesn't take much of a spark to start the pump on fire.
I had a pump that got gummed up by old gas. I removed it and soaked it in toluene (a lot of gas treatments are toluene) until it ungummed. I rotated it a bit by turning the gears with a small screw driver. I've bought a bunch of parts from sasponline.com, but most online stores can give a good price.
Old 05-21-2007, 03:18 PM
Good call Doug, i forgot to mention fuel safety. You should also wait awhile to let excess fumes evaporate.
Old 05-21-2007, 09:58 PM
Thanks for the help. I sprayed wd40 on the pump and then add 12 volts to it. It did work. It took a couple of tries, but it worked.
