Old 05-20-2007, 03:47 PM
dpadd13 dpadd13 is offline
98 blazer clutch issues?
I have a 98 blazer and it will no longer shift out of first gear. I dont know for sure if my tranny is shot or if my clutch is shot. The fluid is brown and smells burnt. My roommate did a tranny flush a couple of weeks ago and there wasn't any metal shards in the pan so we are both thinking the clutch is burned up. Any other ideas?
Old 05-20-2007, 07:31 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 blazer clutch issues?
How is the fluid level?
Got fluid in it?
Any check engine lights?
What engine and transmission or repair history?
What kind killer flush what kind of fluid and cleaner and was the filter changed?
MT
MT
Old 05-23-2007, 03:19 PM
4.3L motor, stock transmission, the fluid is there and it is brown and smells burned, the check engine light is on and the code is slipping tranny, not sure what fluid was used, filter was changed yes.
Old 05-23-2007, 03:42 PM
vtmecheng vtmecheng is offline
What clutch are you referring to? Unless I am picking up the wrong vib, this is an automatic which means there are multiple clutches. Usually when clutches start going in an automatic you will notice slipping when it changes gears. I really don't know much about these tranys so can't help much. Good luck troubleshooting, I know how frustrating it can be.
Old 05-23-2007, 04:24 PM
MT-2500's Avatar
AF - Advisor
Does it back up or only low gear?
What is the code no?
Have you had it on a good transmission capable scanner?
MT
MT
Old 05-23-2007, 06:20 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Sounds like the tranny is cooked, it needs a rebuild. I would still, like MT said, get it on a scanner and see what its doing. This will give you an idea of what needs attention inside the transmission.
Good Luck!
