Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-20-2007, 03:32 PM
20zetechzscort 20zetechzscort is offline
Exclamation no spark, no fuel
i just bought a 90 talon tsi awd, i was told from the guy i got it off of that it was the fuel pump and or filter, i replaced the pump cause i was not getting fuel past the fliter, now that i replaced it i have presure, but i take out the plugs after trying to start it 4 or 5 times and their not wet, and i also tested to see if i was getting spark and no spark? im thinking crank sensor? any other ideas?
1998 ford zx2:
bomz cold air intake
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-21-2007, 06:47 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: no spark, no fuel
The first thing I would do is pull the ECU and make sure the caps aren't leaking all over the board. It's pretty common for them to take out the injector drivers.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-21-2007, 04:17 PM
but that would not caues it not to spark. or would it?
Edit: what should the restance be in the plug wires..i tested them and i got from 3.1 to 5.3 ohms
edit #2: ok i did some tests and im deff. not getting spark and the injectors are not getting gas into the chambers. i am getting gas to and past the fuel rail. i took off the return line one the rail and turned to key and a shot of gas came out, so i know i have presure and gas is getting through the fuel rail. so im still thinking its the crank sensor, and i could not get my dash apart to check the ecu. im going to try it again later , does any one know where i can price a crank/cam sensor? i checked at the local patrs store and they want $235.00..!
1998 ford zx2:
2 baja 12" subs
250 no name amp
sony head unit
1990 eagle talon:
mods to come
Old 05-22-2007, 06:57 AM
Someone will have to back me up on this, because I'm not sure about the 1g's. The ECU won't run the fuel pump in a 2g, unless it gets feedback from the CAS. So if you are getting fuel consistently, that isn't your problem.
I would still work on checking the ECU. That is the most common culprit of fuel and spark issues when it comes to a 1g.
1997 Spyder GS-T
5-Speed
Old 05-22-2007, 07:13 AM
Scrapper Scrapper is offline
AF Premium User
i agree ECU no fuel no spark no start..
Old 05-22-2007, 09:47 AM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
its your ecu like everyone eles said they only last so long
Old 05-22-2007, 10:12 AM
AF Premium User
yes because they would be out of money if they made them to last lifetime...still good luck 2 you...
Old 05-24-2007, 07:27 PM
spyder9789 spyder9789 is offline
My old spyder GS had similar problems. It died on me one day and wasnt getting a spark but I was getting fuel to my injectors. It was my crank sensor. Once that was replaced only two of my cylinders were firing. Replacing the Power Transfer Unit fixed that problem.
