Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-20-2007, 02:36 PM
coltonk coltonk is offline
85 4Runner - rough idle
I just got this 4runner and it was driving fine but on the way home one night it started running very rough(like it was only running on 2 or 3 clyindars).
Ive checked spark, timing, gas, cant see any vacuum leaks...
Can anyone suggest anything that may be the problem. ...
Ive replaced the distributor cap/rotor/wires...
Old 05-23-2007, 09:20 PM
OzzyO's Avatar
OzzyO OzzyO is offline
Send a message via MSN to OzzyO Send a message via Yahoo to OzzyO
Unhappy Re: 85 4Runner - rough idle
I have the same problem with my 4Runner, it's a 1994, 3 Liter V6, and as soon as it gets fixed I'll Post here to let you know , in case it may be the same thing. It's been at the garage for about a month now and hopefully, I Pray To GOD, they will find the problem soon.
Good Luck, I Should Know Within 2 weeks from today, Sorry, thats the best I can do for now.
OzzyO
Old 05-25-2007, 07:44 AM
Thanks OZZYO,
I can't believe that no one else has had this problem. Ive checked everything except engine compression.
Ill keep hoping that someone has a solution.
Old 05-26-2007, 05:53 PM
OzzyO's Avatar
Question Re: 85 4Runner - rough idle
Alot of people have had this problem and it's Not Only with Toyotas, all the major car dealers are having some customers with these problems, although it seems it's mostly with vehicles that are older and have alot of miles/ kilometers on them.
Google it yourself, it's kinda interesting.
As soon as I know I'll Post it here Coltonk. Hang in there bud my 4Runner is laid up over a month now so I know how you feel. And as I said I should know in less than 2 weeks now.
OzzyO
Old 06-06-2007, 09:27 AM
OzzyO's Avatar
Cool Re: 85 4Runner - rough idle
Well I found out what the problem was with my Rig,,,, turns out it was the O2 Sensor and it's the second time it's been replaced in 8 yrs.
They also replaced the fuel pump, fuel regulator, and the Mass Air Flow Sensor, needless to say it cost a small fortune But it's fixed
So in the end what was causing all the hesitation , bucking, no power and stalling was the O2 Sensor. I Hope This Helps You With Your 4Runner.
Ozzyo
Old 06-06-2007, 10:00 PM
Thanks Ozzyo,
Ill have to see what I can do this weekend, I do know that the O2 sensor is one of the error messages from the computer system.
I appreciate all the help!!!!
Old 10-07-2007, 11:52 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Originally Posted by coltonk
Thanks Ozzyo,
Probably your broken valve spring....
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-08-2007, 07:45 PM
Thanks alot brian... All the time I spent trying to figure out whats going on and you knew what the problem was..hehehehhe
Old 10-08-2007, 10:17 PM
Brian R.'s Avatar
Resident Chemist
Someone had to divulge the answer
