Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-20-2007, 01:29 PM
ctanori ctanori is offline
95 maxima misfire code p0306.
I swap sparkplug 5 &6, I swap coilpack 5&6
and still misfire cylinder 6.
Does anybody knows what is wrong, should I Swap injectors too?
Old 05-21-2007, 01:08 AM
Toolman5523 Toolman5523 is offline
Re: 95 maxima misfire code p0306.
You could try to swap injectors, however there could be other issues. Check for rodent damage on injector #6 wires. The main harness that runs along the strut tower is notorious for breaking and causing problems. Unfortunatly Nissan has a problem with those coil packs on those engine's, and even though it says #6 misfire the computer is not always that acurrate for diag. Nissan actually recommends to change all the coil packs at the same time (ouch) and to always run factory s-plugs.
