Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-20-2007, 11:09 AM
Robs97KingCabPU Robs97KingCabPU is offline
2001 Rodeo Maintenance schedule?
Does anyone know where I can find a maintenance and lubrication schedule for a 2001 Rodeo? I don't have the manual, and I did not see one in the FAQ section. I'm most interested in what it says for maintenance on the auto transmission. Does it call for fluid/filter changes (and how often), or does it also call for power flushes (again, how often)? Thanks.
"I'll feed their greed with my need for speed"
Old 05-20-2007, 01:55 PM
surferfletch surferfletch is offline
Re: 2001 Rodeo Maintenance schedule?
I don't know what the manual suggests for the 4L-30E, but I've been draining/refilling about 3 qts every 15K and dropping the pan to change the filter, gasket, and about 4 qts every 30K. Shifting smoothly at 160+K. What's the history of your truck? Is it new to you? If so, I'd drop the pan and change the gasket/filter if you're over 45K and uncertain of the maintenance history.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 05-20-2007, 03:06 PM
I'm going to be taking mine in for warranty work on the tranny in the next couple of days, and they are already warning me to bring reciepts. The tranny has 116K miles on it, I'm the original owner, and I have changed the fluid and filter every 35K or so. I've never done a flush on it, but it has started to slip, and the fluid looks dark when I last changed it about a couple weeks ago. I've had it in to the dealership a couple of times in the past for leaking (same place everyone elses leaks, that accumulator valve cover), and they repaired it both times, so we will see. I just see myself having to get ready for a fight here, as I don't have any receipts to show them. I could maybe get a copy of the last filter/gasket I got from the Autozone I got them from, but that would be about it.
Yeah, good advice indeed. Problem is though, from scanning through NUMEROUS threads about the 4L30-E, there seems to be just a lot of guessing as to what is required for maintenance. Sounds like you are doing the right thing for sure, but I'm trying to find out what Isuzu recommends.
Old 05-20-2007, 03:21 PM
amigo-2k amigo-2k is offline
Isuzu Guy
I've been flushing mine about every 30k. once I hit 90K I'm going to have the pan dropped and have the filter changed and then wait a year and start flushing it again. If I get close to 180k I'll do it again, but I doubt I'll own it that long (15years would be a long time to own a truck).
I think the manual states 100k tranny fluid change unless you use the truck in extreme ways (tow or 4x4 a lot).
I'll still try to check the manual tonight....
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 05-20-2007, 03:24 PM
Isuzu Guy
http://www.mjw.com/amigo/tech/maint.htm
For a 98 it says just check every 15k.
-Ryan
Isuzu Moderator
Car Show Tips
Old 05-20-2007, 03:29 PM
Hey, thanks for the link. Yeah, if it's the same schedule for my 3.2L, then I don't know how they can ask for reciepts. Sounds like if you go by Isuzu's maintenance schedule, you would never do a filter change, or flush, at least not before the 120K warranty period (?). I really need a manual !
Old 05-20-2007, 07:27 PM
Isuzu Guy
I checked my 2000 manual and it says check for leaks every 15k and check fluid at 120k to determine if it needs to be changed.....
-Ryan
Isuzu Moderator
Car Show Tips
Old 05-21-2007, 12:15 AM
Ramblin Fever Ramblin Fever is offline
Not for me, I guess. We had our late toyota almost 17yrs, we probably should've thrown in the towel at 15yrs, but then it had 250k or so.
Our '91 Rodeo owned us for 12yrs, got rid of her too soon, IMHO, she still had less then 200k and running VERY good, we only traded her because we needed an open-bed full size p/up to carry our camper - wish now that we had waited a few months to save a down payment and kept that Rodeo.
Our '97 is currently sitting at 10yrs/174k miles, but is now only being drove on the weekends, and maybe 1 day a week, so the mileage will drastically slow down, and at this rate, it'll be around a lot longer with only averaging what we would figure to be maybe 5-7k miles a year. Depending on how many sight-seeing adventures we hit up on the weekends, and how bad the winters continue to be, as the BMW is NOT fit for snow driving.
I can see someone getting bored with a vehicle after 12-15yrs though, that does play a big factor in replacing them, or if a family grows too big.
For us, we've discovered the only way to get and stay a bit ahead financially, is to wear out each vehicle totally, as long as it doesn't cost more to keep it running then would otherwise spend on a newer one.
Believe me, I like the power in the BMW and gas mileage, but it is really NOT all that comfortable to drive. But, paying $2k for a 22yr old car left us $15k ahead of the game for not buying a new toyota corolla, with the same, maybe slightly less gas mileage.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 05-21-2007, 09:18 AM
Okay, found the manual. According to the original print, the only required maintenance on the auto tranny is to check the fluid level, and the first time is not until 120K miles! However, I remember when I bought the vehicle, the salesman placed a sticker in the owners manual showing a change to this. This new line shows it should be checked every 30K miles. I looked throughout the owners manual and could not find any requirement for filter changes, changing fluid, or flushing. Seems like owners are just discovering by chance (usually the hard way), or by forums such as these, that doing these type of maintenance procedures are just about necessary for this tranny !! Either way, I cannot see how the dealership/Isuzu can ask me for any kind of reciepts when I take it in, as the only requirement according to my factory owners manual is to check the level, right?
Old 05-24-2007, 07:25 AM
Well, I'm definitely a happy camper ! Just got the news from the dealership that they are going to replace my tranny under warranty, so no cost to me! At 116.6K miles, I could not have timed it much better, eh? Still, valuable lesson here for anyone doing work on any vehicle; keep your reciepts and good documentation on everything done.
Old 05-24-2007, 09:53 AM
Isuzu Guy
Thanks for reporting back! i have a notebook that I staple and write down everything that I have done to my truck. I hope I never have to bring the notebook into the dealer (only 3.5years or 42k to go ...).
-Ryan
Isuzu Moderator
Car Show Tips
Old 05-24-2007, 03:19 PM
Great news!
Remember, from here on out, MAKE sure to do partial fluid swaps every 15-20k miles, if you do this, that tranny will last a LONG time. Change your filter every other time, and try not to lead foot the truck on take-off's, this is the hardest on these tranny's.
1997 3.2L V6 Rodeo
Old 05-24-2007, 04:03 PM
Well, two out of three I can manage (fluid, filter changes). The lead-footin'...
Thanks for the support, and the great info, fellers. I hope to keep this vehicle for a long time also.
Old 05-24-2007, 11:20 PM
You must feel like you just stole something! $3K worth of something!
Old 06-03-2007, 09:23 PM
TX-LS's Avatar
TX-LS TX-LS is offline
Okay, just to follow up; I got my Rodeo back a couple of days ago, and it is perfect! Didn't cost me a penny, but the only thing I forgot to ask was what kind of warranty I get with the new tranny. I called them and they will be getting back with me about it, so I'll post when I find out.
Oops.. sorry for the confusion. I'm the same guy who started this thread, but since I don't have my '97 Nissan pickup anymore, I figure I should change my name to suite my current vehicle.
