Old 05-19-2007, 06:37 PM
DodgeStealth91rt DodgeStealth91rt is offline
91 Stealth R/T Intake
So I bought a after market intake and unfortunately I have a MASS, my problem was my MASS adapter fit perfectly but the other side of the MASS was shaped like a huge oval that only a 4" to 3" plumping fitting fitted too. Now I got it all togeather it 90's out of my intake and then 90's again to sit right by my battery. I reset my ECU by removing the + terminal from the battery and now my car runs like crap. Hit the gas and it is very spontaneous and wants to stall a lot. Any pointers on what I could of done wrong?
Old 05-19-2007, 10:20 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 91 Stealth R/T Intake
check to see that your MAS is plugged in.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-20-2007, 11:51 AM
The problem was simple, with the after-market piping I was getting more air then fuel so I switched to my stock piping {ugly but works)and it still gives me the desired affect. Before anyone asks I did reset my ECU with the after-market piping installed.
Old 05-20-2007, 12:26 PM
Linebckr49's Avatar
there's no reason to reset your ECU when installing an intake. tell me, was this intake just a filter? the pipe/tube? or both? was there a vacuum port on the intake tube?
its really a simple install; i'm sure you just accidentally overlooked or forgot to plug something in. i'm a bit confused by your first post, but it seems like you first had a fitment problem where unfiltered or unmetered air was leaking into the system. then you fixed that problem with the 90 degree bends, but it should have worked fine at that point.
if you could post a picture, i'm sure we could get it all straightened out.
welcome to AF!
93 3000GT base
Old 05-20-2007, 09:02 PM
Hotshot8792 Hotshot8792 is offline
word of advice, when your disconnecting your battery, unplug the negative terminal first and always connect the negative terminal last.
And yea, i don't understand what your saying about whats wrong, but as linebcker said post a picture
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
