Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-19-2007, 03:42 PM
Ferngee Ferngee is offline
Send a message via AIM to Ferngee
96 maxima 3.0 engine will not start at all!! Help!
I have a 96 Maxima with a 3.0 engine in it.. It will not start at all .. the only codes popping up are P0443B- which pertain to evap purge system. None of the six coil packs are getting fire to them. What could it possibly be??? What can you all recommend?... by the way...Car will turn over..but will not start.. plenty of fire from battery..
Old 05-21-2007, 02:46 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 96 maxima 3.0 engine will not start at all!! Help!
ECU drives the ign coils: ECU can be damaged, more possibly two critical sensors simultaneously 'dead'. CAM/Crank sensor plus MAF?
(Inhibit switches like security, gear selector, brake pedal sw kill the starter circ...)
Check this page http://www.cardomain.com/ride/748507/14, also p.9
Old 05-22-2007, 06:58 PM
Toolman5523 Toolman5523 is offline
Well, a Mass airflow sensor will not cause a no-spark concern. And the chances of two sensors going south at the same time, slim. The ecm controls the firing of the coils. Make sure your inputs to the ecm are good especially batt. and ground. Check to see if you are getting anything to the coils: volts, signal, ground. Then check your ecm, make sure no water damage from a/c, or bad motor mount smoked it. Yes, a bad motor mount if it is electric, and it shorts out internally can fry an ecm
Old 05-22-2007, 07:37 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
I have a Question back to you .. Do your Keys have a Chip in it? If they do , that will cause the no spark .
Old 05-22-2007, 08:51 PM
I believe the Nats system equipped on the early models would just shutdown everything. No spark, no fuel, not even crank.
Old 05-22-2007, 09:58 PM
You might want to start checking the harness, input and output voltages. It seems like you have a sudden bunch of problems from what i have been reading. Either a wiring problem or Ecm problem. I actually have a good Ecm for a 96 max i believe and Tcm.
Old 05-31-2007, 02:37 AM
ModifiedMCS ModifiedMCS is offline
If your car cranks, but no start. I would check the crankshaft position sensor. That sensor let the computer know when piston #1 is TDC for spark and fuel and so on.
Old 05-31-2007, 08:18 AM
The Nissan manual indicates that in such case (any single sensor failure) the engine would be runnin in safemode (=2.2k rpm ceiling). ... Easy to tst by unpluggin sensor wire.
