Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 05-19-2007, 02:31 PM
Benesesso Benesesso is offline
Location on ECM Computer-1995
I suspect my ECM computer is bad or has a poor connection. I removed the round panel below the glove box and found 2 "computer-like" small boxes. The larger one on the left was brown, with the numbers 14101255 and 5025 inked on it. The smaller black box had no numbers. However, on eBay it seems that most used computers start with 161XXXXx.
Have I found the ECM or not?
Old 05-19-2007, 05:17 PM
GregA's Avatar
GregA GregA is offline
Re: Location on ECM Computer-1995
I believe it is called the PCM (Powertrain Control Module) in this particular van.
Anyway, check the following link for location:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 05-19-2007, 09:29 PM
Thanks, Greg
I found it and wiggled all the connectors while the engine was running, all seems OK. In the Autozone view the computer has been partially removed--mine is along the left side of thje area.
A while ago this van started to momentarily lose either 12v or ground to the whole car--every so often. Only lasts a second or two. I have checked and rechecked all the battery connections, and everything close to the battery (and the batt. itself) in the electrical circuit, but I cannot find this problem. Even removed and replaced every fuse I could find.
