| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Hi, My problem is that for the past 4 years my fan switch goes out when the season starts for air conditioning. It just went out again. has anyone ever run across this problem? I am guessing that is what the part is call. Its the part that goes on front of the fan. See image.
http://i82.photobucket.com/albums/j2.../fanswitch.jpg Thanks for your time. |
Re: fan switch keeps going out on 95 Mustang
I would think its a load issue with the fan. Over time, it blows the switch. I would chage the fan, and see if solve the problem.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Thanks for the suggestion. So do I change just the fan or all of the parts associated with it? |
If you could just change the fan motor, I think that would solve the issue.
I would check the radiator first to make sure that the radiator is not clogged. If the radiator is not clogged then I would look to see if the radiator is a 1 row radiator. If the radiator is a 1 row radiator, I would replace the radiator with a 2 or 3 row radiator. I had a 1990 Mustang with dealer installed A/C and had the same problem. The problem was resolved once I change the radiator from a 1 row to a 2 row radiator. The dealer apparently did not change the radiator when they added the A/C.
Alright. I figured out it was the thermostat. The fan was working it is automatic and wasn't on when I was looking. Thanks for your help.
Glad it was that simple.
