Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 05-19-2007, 12:48 PM
Delsol2957 Delsol2957 is offline
werid Sounds.....oh no
Hey, My car when im siting at an idle is making a loud squealing sound and i really not sure what it could be, you think maybethe timing belt? and also it idles up and down(the rpms keep going up and down) do you have any ideas how to fix this?
Old 05-19-2007, 01:39 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: werid Sounds.....oh no
Squealing means a belt but not timing because it's ribbed and won't slip like that. Go to the right side of the engine where the accessories are and get a spray bottle. Spray a little water on each belt until the squealing stops and bam, you've found the problem belt.
As for the idle problem, the first thing to check for is vacuum leaks. Are you getting a check engine light?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 06-08-2007, 10:26 AM
No, Im not getting a check eng. light
