Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-19-2007, 09:36 AM
mebrown mebrown is offline
Transmission Issues
I have a 2000 Camaro EX-state police vehicle with 99,000 miles. It will not shift into drive/overdrive. Changed the filter and fluid to no avail. Any thoughts or suggestions. Thanks
Old 05-19-2007, 10:46 AM
Scrapper Scrapper is offline
AF Premium User
Re: Transmission Issues
new tranny time i'm sure that the tranny module is inside tranny..one thing you might try is make sure al vaccum hose are's hook up and ok no leaks..
good luck...
Old 05-19-2007, 11:36 AM
Morley Morley is offline
There are no vacuum lines going to the transmission, there haven't been vacuum lines going to GM transmissions since the days of the TH350. When will people learn this?
Old 05-25-2007, 07:56 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
i believe you have the 4L60 (non-electronic), instead of the 4L60e. if this is true there should be a connector on the driver side of the transmission.... it has 3-4 metal connectors inside of it. make sure that connection is actually plugged into the tranny. it controls the torque converter lockup. check the wires for damage.
if that doesnt work, you may have an electronic tranny (that im not completely familiar with the internals), or a problem with servos, worn out band, or speed senor problem. could be a lot of stuff.
any other symptoms? early shifts? slow shifting? is that the only gear?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 05-26-2007, 12:02 AM
A 2000 will be a 4L60E. The PCM controls transmission shifting. Check all of the electrical connections. After that, it is rebuild time.
Old 05-26-2007, 11:49 AM
ok.
what year did they start using all electronically controlled transmissions? '96?
Old 05-26-2007, 12:00 PM
Originally Posted by instantkevin
ok.
1994, second year for the LT1 they switched from the 4L60 to the 4L60E.
