Old 05-19-2007, 12:13 AM
1BadBowTie 1BadBowTie is offline
Send a message via AIM to 1BadBowTie
Weird Miss??
Im stumped, even have a few people who are good with cars stumped on this one, a 99 1500 with 5.7 vortec, only misses after full throttle. after u get back on it again, it clears up. i also noticed it doesnt run extreamly smooth at idle.. i threw in a lot of fuel injector cleaner, new AC plugs, good set of carquest wires, cap, rotor, and still it does this... i also experiance poor gas mileage... roughly 12 mpg.... any ideas why this could be doin this???
1998 K1500 Silverado 350 5-Speed
1999 Lumina LTZ
1984 Oldsmobile/Hurst
Old 05-19-2007, 12:37 AM
jshort74 jshort74 is offline
Re: Weird Miss??
Fuel filter?
Old 05-19-2007, 01:49 AM
mr_mushroom's Avatar
mr_mushroom mr_mushroom is offline
Send a message via AIM to mr_mushroom
Re: Weird Miss??
timing drift a little off?
seems like that would set off a check engine light though.
maybe hook up to the OBD port and check if there's any recent momentary codes stored in the memory. also make sure the light even comes on when you turn your key to 'on', i had one shake loose once and fail to notify me that the ignition was blowing up.
might be a start.
all your are belong to us.
Old 05-19-2007, 01:59 AM
MyTOY's Avatar
MyTOY MyTOY is offline
Re: Weird Miss??
my 5.0 had similar probs after all the usual stuff replaced with
no codes and like your 5.7 was CFI until I had the injectors
replaced with MFI. It runs perfectly now but at the cost of $700
for parts & installing. The dealer has equipment to clean the CFI,
but I hear this can only be a temporary fix for these poppit injectors.
I had already cleaned my MAF & EGR & of course fuel filter first thing
like jshort said and after I had the fuel pressure tested. Most folks
will target the distributor for a miss for a bunch of good reasons
but I think usually a misfire code is involved. If its just an idle prob,
most will say to check EGR system or coolant temp sensor. There are
methods for checking these but assuming you have no codes stored,
I would bet your injectors need to be professionally cleaned. GOOD LUCK
03 WRX
Old 05-20-2007, 10:08 AM
markqc markqc is offline
Re: Weird Miss??
You may want to try a set of GM wires to see if it clears up the problem. I had replaced my wires with Bosch wires (6 months ago) and had problems with misfiring on two cylinders when at cruising speed. I changed the cap with little to no differece. If I accelerated or coasted the misfire seemed to go away. I changed the wires and problem has gone away for now.
Mark
Old 05-20-2007, 05:07 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Re: Weird Miss??
Delco wires are pretty good. Next time you change wires check their resistance agianst Bosch, Accel, etc., whatever you have.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 05-22-2007, 05:48 PM
Evsman Evsman is offline
Re: Weird Miss??
I can't help you. I have the exact same problem. A 1999 K-1500 with 5.7 misses just like you have described. i changed the cap, rotor, wires, plugs, and had the injectors cleaned. It still does it. But it is intermittent. Sometimes it doesn't do it it all and other times it will barely keep running. No trouble codes and the problem appeared all at once. Ran great and then all the sudden one day it started doing this. If you figure it out let us know!
Old 05-22-2007, 06:55 PM
2000CAYukon 2000CAYukon is offline
Re: Weird Miss??
This sounds like a leaking fuel pressure regulator to me. When you let off the throttle, the vacuum is higher at the fuel pressure regulator and extra gas gets into the intake causing the miss (the PCM sees the extra fuel and tries to lean it out). It would also explain the bad gas mileage.
//2000CAYukon
Old 05-28-2007, 10:18 PM
Re: Weird Miss??
wow, sounds like i have a lot of checking to do, but i had the timing checked and it was off, but even set right it still does it.. so im leaning towards a bad injector.. probibly why it doesnt run all that smooth at idle.. but if anyone has any better ideas, let me know hehe... thanx guys!!!
1999 Lumina LTZ
