Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 05-18-2007, 08:00 PM
1997 blue sierra 1997 blue sierra is offline
transmission
I have a 1997 GMC Sierra 4wd. I recently had the transmission replaced. Now sometimes usually when it is cold I'll put in gear and sometimes I have to wait 3 or 4 seconds before it will go into gear. I give it gas and it is like it is in neutral. Is there any vacuum associated with the transmission. Also sometimes when I take off it will slip out of gear, and feel like I'm neutral and go back into gear again. This is becoming annoying. Can you guys help me out. Also I have no engine codes.
Old 05-18-2007, 09:45 PM
2000CAYukon 2000CAYukon is offline
Re: transmission
It is possible that the fwd accumulator is leaking either at the pin or seal. See http://www.transmissionspecialty.com.../77754-01K.htm
Of course, the clutches could also be burned.
//2000CAYukon
Old 05-22-2007, 05:56 AM
Regalwhiskey's Avatar
Regalwhiskey Regalwhiskey is offline
Re: transmission
Sound like the fluid could be low also
Re: transmission
Check for burnt fluid on the dip stick, which will indicate clutch wear.
