Old 10-22-2002, 03:36 PM
follow_the_smoke follow_the_smoke is offline
Question fuel injection swap?
hi, 90 honda civic DX and want 90 Si fuel injection put on it, whats needs to be done?
wiring and parts needed?
Old 10-22-2002, 09:07 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
You need a fuel tank and fuel pump out of a 91 Si and you will also need the Engine Harness out of the si and the underdash harness. Correct me if I am wrong I may be. Are you swapping over to a B series DOHC?
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 10-22-2002, 11:25 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
NO
U acually need the following.
1. Si intake mani.
2. si ecu
3. si dizzy
4. injector resistor(sp?) boxs
and u will need to wire in the two extra injectors. that is it. if u need more info ask the guys and girl on 88-91 forum
My Name is Roberto AKA. Berto
Old 10-23-2002, 03:05 PM
no, my friend has a dx and he did all this stuff to engine, and all he wants now is the differnt fuel injection
thanx
