| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
Hi gentlemans, i had a 1999 325c, few months ago i change all the coolant system: pump, lines, radiator and coolant deposit. Everything is new, but i had this problem:
The temperature gauge mantain the same indication, so i never had an overheating, but sometimes i loose all the coolant liquid by the cover of the deposit. This happend after 2 days of use, never before. Now, sometimes i open the deposit cover in cold and release air pressure. I dont know if the coolant system had a valve for release this air or what. I also try with the screw placed on the deposit to keep only the liquid, but doesnt work. Anybody had an idea to fix it? Regards, R |
#2 | |
Re: 325c Coolant overpressure
You should have a bleed screw on the thermostat housing, start car and let her idle, then open the bleed screw a bit (until coolant starts to flow), let coolant flow slowly (if you see bubbles in the coolant, let her flow until bubbles disappear) the tighten bleed screw and see what happens (this may take a couple of trys).
#3 | |
Ok, thnks a lot
#4 | |
![]() Join Date: Mar 2006
if all your coolant is dissapearing and your getting air pressure in your radiator, when the car is cold, open the radiator cap and let all of the pressure out, put it back on and run the engine for 2-3 min, if you have air pressure in your radiator again it sounds like your head gasket may be blown
The only time something cant be done is when you dont try hard enough |
