Old 05-18-2007, 03:17 PM
thedeadcivic's Avatar
thedeadcivic thedeadcivic is offline
D16A6 turbo swap
im planning on swapping my d16a6 with another low km turbo'd d16a6.
will i have to change my ecu or my timing because of the turbo? or could i somehow get around that. im trying to avoid any ecu reprogramming. i know i can swap the engine no problem with no changes to the ecu, but im not sure what needs to be done after installing a turbo.
help me?
90' Honda Civic Si
2001 Volkswagen Golf 1.8T
Old 05-18-2007, 05:17 PM
Hybrid1990crx's Avatar
Re: D16A6 turbo swap
well you can do it, and run it with no tuning, but it won't run very long.
Old 05-18-2007, 05:45 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
A VAFC will be the bare minimum that youll get away with, and at around 6 PSI it should live for awhile. Any more than that and your fuel pump wont be able to handle it.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-18-2007, 05:55 PM
what needs to be done then to ensure that it runs good? do i need a new fuel pump? or, where do i go to get it tuned properly?
90' Honda Civic Si
Old 05-18-2007, 11:45 PM
vafc isnt a very good tuning device. infact it doesnt work at all on a honda unless you do the vafc hack. if you don't believe me look into it some more.
Old 05-19-2007, 04:04 AM
FrodoGT's Avatar
I didnt say it was good tuning advice, but he said he wanted the bare minimum and little to no ecu modification.
Current project:
Rio Red 91 hatch.
Old 05-22-2007, 11:15 PM
ok now im not looking for the bare minimum. i dont want it half assed. can i get someone to tune my ecu as it is - or can i buy one ready made for a turbo? im trying to make a list of what i need to do this.
90' Honda Civic Si
Old 05-25-2007, 10:13 PM
welfarepc welfarepc is offline
haha blow your car up OP!!
its really simple to tune your car for turbo, get a 90-91 si ecu (pm6, which it looks like you have) chip it, and get turboedit. go to ebay get a willem eprom programmer with a few 27c256 chips and a uv eraser or some 29c512's if your a baller, borrow a wb02 kit and do that shit up
if u want someone to tune it you gotta upgrade to odb1 and run chrome or something more common then turboedit, unless you can find a turboedit tuner....
