Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-18-2007, 09:36 AM
Turbofestiva's Avatar
Turbofestiva Turbofestiva is offline
Exclamation C32b With C32a FWD tranny?
OK. This is all i want to know. Will the C32b Dohc VTec motor from a NSX bolt to the front wheel drive tranny in a 95 Acura Legend? The stock Legend motor is a C32a sohc non-Vtec Also will it run good?
IF it works it would be a sweet combo
Old 05-18-2007, 11:05 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: C32b With C32a FWD tranny?
Hmm it SHOULD bolt up (C series engine to a C series Tranny) although the NSX is a Rear engine rear drive car..so the tranny should be set up like a FWD tranny.. so why not use the NSX tranny and fab some mounts?? ... but that assumiung it will fit... there has to be a reason you dont see this swap done...
