| F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
okokok... Header Question
Alright here's the deal.
The heads I've got are of a 71 vette (pretty sure they're 71's, the guy said they're one year only and VERY good heads... for whatever that's worth) that have been ported "a LOT, but done well". They're on a 454, with a comp cams cam (not sure which yet, still looking for a stamp on it) with a 3" exhaust. I'm guessing what I have will work ok, but not sure if it's right. The new ones are the same dimensions as the old headers I took off. Question: The header's I got are Dynomax Ceramacoats - 1.5" primaries and 3" collector, is that right or should I be looking for a bigger primaries on the headers since the heads are ported pretty heavily? |
Re: okokok... Header Question
Now I am no mechanic but I would think you would want your headers that go to the heads, the opening to be the same size so you don't get a lot of turbulent are affecting the exhaust gases leaving the heads. But like I said I am no mechanic.
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
For a big block you want 1 7/8" primaries...I'm running 1 3/4" primaries on my 350 and that is the recommended size for a well built 350.
So I should be looking for something around 1 7/8" - 2" into a 3" collector?
(I shouldn't be looking at going to 3.5" exhaust or something like that should I?) |
1 7/8" atleast 3" collectors should do and 3" mandrell all the back would work, btw really sorry to hear about earl
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
Thanks, it been really hard to accept he's gone.
Thanks for the info guys... gotta make some phone calls now. (I KNEW I shoulda asked first... DAMMIT!) |
Yep, go 1 7/8" primaries to a 3" collector and 2.75-3" to mufflers and out.
Hmmm... It has a full 3" exhaust on it. WHICH some jackass put 2.5" pipes on after the mufflers to make it street legal. I think I'm going to put the turn downs back on (after the mufflers) and get rid of the 2.5" extensions.
