Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-18-2007, 01:41 AM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
water cooled oil cooler
I've been attempted to locate the oil filter housing for the 1g swap i had to do...no place in town has it except I can order it from the dealer ($432.14 later). I've also read all the info on the magnus motorsports 1gina2g.pdf swap info and it mentions "1G Oil Cooler (90-92 MD 157670 6bolt water cooled oil cooler)". I want to be able to use my water cooled oil cooler from my 97 gst, but its not directly compatible. Does anyone know what that part number references or have any info on how I can fit my 6 bolt with a water cooled oil cooler? Does anyone have the housing i need for sale?
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 05-18-2007, 02:01 AM
Re: water cooled oil cooler
i never owned a 1g turbo or i might have the answer to my own question here though. I know the difference between the filter housing...the 7 bolt housing has a female connection which the oil cooler bolts to using a double sided male threaded pipe which the filter bolts to.
Ive been searching the internet for days looking for the 1g equivalent, knowing that the 6 bolt housing uses a male threaded pipe, my oil cooler would not bolt to it...ive found this though
http://www.vfaq.com/mods/oilcool.html
Is this what that part number mentioned in the last post is? (besides the fact it is sawed in half) if so, how much and give it to me. Now I am just trying to piece this together mentally though. if this version of the oil cooler is female threaded, and bolts to the male threaded housing, how does the filter bolt to it?
72 Beetle - trashed
92 Talon - sold
Old 05-19-2007, 03:01 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Why not just run and external air cooled oil cooler?
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 05-19-2007, 03:17 AM
cause water cooled is more efficient, plus my car already has the lines for the water cooled oil cooler.
72 Beetle - trashed
92 Talon - sold
Old 05-19-2007, 03:38 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I've never heard of or seen one of these water cooled oil coolers... Got any pics?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-19-2007, 12:54 PM
this is one off of 2g, stole the link from another thread...but this is what mine looks like. there is a 3" pipe that goes in the middle that inserts into the housing...the filter screws on the other end. ive been told there is a 6 bolt version of this though. the dealer cant seem to locate the part number though
http://www.automotiveforums.com/jaco...r/DSCF0034.jpg
72 Beetle - trashed
92 Talon - sold
Old 05-19-2007, 01:07 PM
http://www.automotiveforums.com/jaco...r/DSCF0031.jpg
mine looks like the housing on the left, except the left bolt hole is closer to the center, and the bottom one is almost directly below the center oil hole.
it looks like my oil cooler will bolt to that one if it fits a 6 bolt. if not, i am told there is an oil cooler like mine that screws to the housing on the right
any questions or is everyone lost...
72 Beetle - trashed
92 Talon - sold
Old 05-19-2007, 03:41 PM
NOFX0617's Avatar
It was my understanding that the external air cooled ones are more efficient. I thought about it the other day too. Running a non water cooled one you can just eliminate those lines all together so thats just less stuff to worry about.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 05-20-2007, 12:08 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
They only put them on a few different years for some reason. If I'm not mistaken they put them on the 1g 90-91, but I was not aware that they were on any 2g's. They really aren't that much better than the normal air cooled systems. Just more shit to deal with really. My car had one that I simply left on there just because it would have been way more work to remove it.
1991 GSX 2.3 Stroker
Old 05-20-2007, 12:11 PM
Ok, I know what your talkin about now... But what are we trying to figure out here? Just if its worth it or not? I would just stick to an air cooled one. Too many extra lines for leaks and shit...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-21-2007, 12:25 AM
well, the way i figure it is...the water cooled one is already air cooled by radiator...if i already have an oil cooler, why dont i find the housing for it, since i need a housing anyways.
72 Beetle - trashed
92 Talon - sold
Old 05-21-2007, 01:07 AM
this is what my current block looks like
this is apparently what the two different housings look like for a 7 bolt
i drew lines on it to show the position of the bottom hole
this is what they look like for a 6 bolt, see how they are different.
and also ebay item 120121423996
I only thought there were 2 kinds, then 3, now i found 5 different kinds.
seeing that I want to use my oil cooler, which one looks like the best fit.
72 Beetle - trashed
92 Talon - sold
Old 05-21-2007, 01:42 AM
Yeah and recirculating through a 210 degree motor before it cools the oil in the cooler... I donno man, I just don't see it working better than an air cooled oil cooler. If it worked so well then we would see it on a lot more models than just a few rare ones. Which kinda makes me wonder if it was a small test group of DSM's that had them only, and then failed the test. Ya know what I mean?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-21-2007, 10:12 AM
both my 99gst and 97gsx have one, and a friend of mine has a 99gst with it also
72 Beetle - trashed
92 Talon - sold
Old 05-21-2007, 11:02 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
This is what my oil cooler looks like, and it works fine...
http://www.stealth316.com/images/fmoc_toddthomas_1.jpg
edit: grrr... won't let me post the pic... I'll look for another...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
