Old 05-17-2007, 07:20 PM
baddad1717 baddad1717 is offline
idle problem
I have a 2000 ford ranger 4 cylinder 5 speed. While i am driving it and come to a stop the idle revs up and stays there for a while and then go down. any ideas on what could cause this?
Old 05-17-2007, 07:38 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: idle problem
I suspect a vacuum leak somewhere, (possibly related to a defective power brake booster) or a defective idle air controller.
Old 05-17-2007, 10:47 PM
INF3RN0666 INF3RN0666 is offline
Re: idle problem
There's an Idle Air Control valve that opens and closes when you're idling to make the engine run properly without stalling. It's found on the intake manifold. I suggest looking at that first, and make sure it doesn't take forever to close. A vacuum leak would cause high idle in general, or so i would assume.
Old 05-18-2007, 03:57 PM
Re: idle problem
Thanks for the information i will take a look at both items.
Old 05-18-2007, 07:08 PM
mr_mushroom's Avatar
mr_mushroom mr_mushroom is offline
Send a message via AIM to mr_mushroom
Re: idle problem
i had a ranger with that problem.
vacuum line came undone.
good luck!
all your are belong to us.
Old 05-18-2007, 09:17 PM
Re: idle problem
thanks for the info i will look for it.
