Go Back   Automotive Forums Car Chat > Toyota > Solara
Old 05-17-2007, 06:27 PM
[email protected] sfa500@verizon.net is offline
2001 Solora V6 SLE Suspension Rattle
Hello, I own a 01 V6 Sle solora with almost 100000 miles. Whenever the road gets bumpy I hear a noticeable rattling from the rear passenger side, almost sounds like its near the trunk. I have checked and nothing in my trunk is causing the noise. I believe it is coming from the suspension. Any thoughts? thanks guys!
Old 06-03-2007, 03:20 PM
ruredi2gofishn ruredi2gofishn is offline
Re: 2001 Solora V6 SLE Suspension Rattle
I HAVE A 2004 TOYOTA SOLARA SE THAT ALSO HAS A REAR SUSPENSION OR WHEEL NOISE THA SOUNDS LIKE SOMETHING IS LOOSE WHEN GOING OVER BUMPS. PLEASE LET ME KNOW IF ANYONE HAS AN ANSWER. THE DEALER DIDN'T, THANKS! [email protected]
Old 06-07-2007, 08:45 PM
papirringo papirringo is offline
strut mount
Old 09-06-2008, 06:41 AM
EA6BMECH's Avatar
EA6BMECH EA6BMECH is offline
Struts. You can check the mounts, but I'm going with the struts. I've replaced the fronts and have the rears to do. They loose their air pressure (gas shocks) and the rebound gives out allowing the the shock to extend too fast and causing a knocking sound when it tops out. It's not when you hit the bump, it's that second after is when you hear the sound. With that said, still check the strut mount too.
Old 09-19-2008, 07:34 AM
upssnowman upssnowman is offline
Struts are bad the cartridge inside rattles when worn, won't hurt anything they are just getting worn out
Old 09-25-2008, 11:02 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Please make note of the thread dates before responding to one...this one is over a year old.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-10-2008, 07:57 AM
AABob7862 AABob7862 is offline
This seems to be an issue with these Solara's. I just purchased a 99 with 93,000 miles and I'm hearing the noise front and back. i took it to a front end guy and he said the struts were ok but the steering link bushings were worn. How difficult are these struts to change out? They want a small fortune to do the labor and the price of the struts are high too.
Old 11-10-2008, 08:30 AM
Scrapper Scrapper is offline
AF Premium User
struts are not that hard to change but you have to be carful if you don't have the machine they lock in or they got these clams that you but on bench and change them. what i would do is take them off take them to a shop and let them inter change them. could also be your upper bearing plates to on struts.
Old 11-10-2008, 08:40 AM
AF Premium User
wow i never caught that one was old thread.how do they get in there when it's been out dated?
Old 07-14-2010, 04:50 AM
EA6BMECH's Avatar
I'll add to this again and I know it's old, but so was my rattle in all 3 of my cars. Found out that it's the sway/torsion bar in the rear. The 2 rubber mounts that hold it in place get slack. Every time I've checked it, I had it on jacks. Can't do that, gotta have it on the ground. I grabbed that bar, and sure enough it would slid a little from side to side and move a little in the bushing on both sides.
Now you can do a couple things. One, be a cheap arse and unbolt the bracket and stuff a thin piece of rubber what ever between the bushing and bar, or change out the bushings for $30 from Advance Auto. Gotta jack up the car, pull the tire off......THEN, get another jack and put it under the???? I forgot what ya call it? tie rod joint? and lift the suspension up to take the pressure off the sway bar. Now the tricky part is, DON'T yank and bank on the 2 bolts cause you can bust them off.........like I did, but I was able to get the bracket off it bolts to and got it out with allot of 4 letter/compound words, a propane torche, easy out and some luck.
So it your not sure and one bolt comes out, pry the rubber bushing apart and try to slid in a thin piece of rubber, in my case, some heater hose I cut with some grease on it, and call it even and put the bolt back and leave it the fark alone! But!! it works like a charm, all that rattle in the back is gone!! Whooo Hoooo!!!
With that said, make sure that the jack is fastened in place and the tire is secure and nothing else in the wells to rattle around.
Take it for a spin and see what ya think. :-)
