Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 05-17-2007, 05:13 PM
mc89stang mc89stang is offline
Horse & Torque estimate?
89 5.0 w/TFS heads, port & polished cobra intake, 70mm throttle body-mass air to match, 24lb injectors, cold air induction, K&N filter, 1 5/8" headers w/hi-flow exhaust, flowmasters, underdrive pulleys, and 3:55 gears. Just wondering how much horsepower this might produce. Thanks.
Old 05-21-2007, 09:05 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Horse & Torque estimate?
Which TFS heads do you have? I'd say around 280 maybe more depending on the heads. The right cam will really help take advantage of those mods.
1969 Cougar
357w & TKO - 475hp
Old 07-06-2007, 11:38 PM
daveshapellSVT's Avatar
daveshapellSVT daveshapellSVT is offline
Specvgini
yea it's hard to say without knowing what cam your running and how good the heads flow, but i'd say your pretty quick if you have the right size cam. are you tuned yet?
2002 Mustang GT ( 4:10 gears, X pipe, cat back, CAI, Under drive pulley set, Intake plenum, throttle body, Tuned) 13.7@101mph https://youtu.be/btMHZeoZTS0
https://www.youtube.com/channel/UCeu...PX2WMqty2z4aPw
2015 Jeep renegade trailhawk
2017 VW Jetta TSI 1.8T
Old 07-18-2007, 12:15 AM
speedfreak's Avatar
speedfreak speedfreak is offline
Send a message via AIM to speedfreak Send a message via MSN to speedfreak
That was the first thing I thought of.
If we're talking about AFR 165s and a stock cam, I'd guess 250-280rwhp depending on how well it's tuned.
1968 Mustang notchback Roller 302, Edelbrocks, Hookers, side-exits, RRs, Crane 2031, Duraspark, forged slugs, X-Celerator, 650DP, Fidanza FW, RAM clutch, Toploader, Comp Plus, McLeod bell, 15x7s, 1 1/8 swaybar.
1972 Ford Pinto SVO 2.3 turbo, MegaSquirt, T5, 8", etc.
'95 Honda XR600-10.5:1, 628cc, ported head, & more.
Old 07-30-2007, 11:03 AM
Street, twisted wedge with an e-cam.
Old 07-30-2007, 12:02 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
What comp ratio?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-02-2007, 05:45 PM
Originally Posted by SkylineUSA
What comp ratio?
Brand:Ford RacingProduct Line:Ford Racing CamshaftsPart Type:CamshaftsCam Style:Hydraulic roller tappetIntake Duration at 050 inch Lift:220Exhaust Duration at 050 inch Lift:220Duration at 050 inch Lift:220 int./220 exh.Advertised Intake Duration:282Advertised Exhaust Duration:282Advertised Duration:282 int./282 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.498 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.498 in.Valve Lift with Factory Rocker Arm Ratio:0.498 int./0.498 exh. liftLobe Separation (degrees):110Intake Valve Lash:0.000 in.Exhaust Valve Lash:0.000 in.Computer Controlled Compatible:YesGrind Number:M-6250-E303CARB EO Number-225-16Quantity:Sold individually.Notes:Will not work with Speed Density applications. A modified computer chip may be required.
Old 08-02-2007, 06:58 PM
speedfreak's Avatar
"Comp ratio" = compression ratio.
Old 08-02-2007, 07:28 PM
9:1 I think
Old 08-03-2007, 01:14 AM
SkylineUSA's Avatar
Originally Posted by mc89stang
9:1 I think
9:1, that is going to kill your power!
9:1 is almost perfect for boost application, not N/A. If your N/A I would run at least 10.3:1 for better power.
You could stay with 19lbs for this engine, they are good for 325hp easy.
Old 08-05-2007, 04:04 PM
Specvgini
go to the track and see what you run. then you could estimate with one of those hp calculators.
