Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-17-2007, 04:29 PM
gman266 gman266 is offline
Clutch / trans nightmear
I have a 1993 non turbo FWD eagle talon with a clutch that is giving me alot of greif. I took my car to the transmission shop were the trans was rebuilt but now i can not get my clutch to work.. the previous owenr had replaced the orginal clutch with an aftermarket high proformance one witch will not grab on the fly wheel. The clutch listed in parts manuals will not fit eather now. The clutch seems to be too far away from the fly wheel to grip so the fly wheel was shimmed but couldnt be shimmed forward enough to grab still. All this work is beeing done by professionals and they now have no clue what is wrong with the car eather. ( pedal cluster, slaves, all hydrulic elemnts of the cluch have been replaced ) anyone got any ideas?
Old 05-18-2007, 07:37 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Clutch / trans nightmear
Did you adjust the clutch pedal?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-18-2007, 12:28 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Why does this sound like they used a non-modular clutch and kept the modular flywheel? The clutch should bolt right up to the flywheel and pressure plate. If it's being "shimmed" out, there's obviously something not right there. It's a direct bolt up, so there should be no modifying of the flywheel. Maybe it wasn't resurfaced?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-18-2007, 01:06 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Sounds like the flywheel could have been resurfaced past it's service limits. You shouldn't have to shim anything.
make sure the clutch has been bled.
Can you explain this a little more???
Is the clutch making the transmission grind? (that would mean that the clutch isn't fully releasing, which could possibly be a bent clutch fork or a pivot, or an improperly bled clutch or improperly adjusted pedal)
Is the clutch not engaging, meaning you let off the clutch and the car goes nowhere??? (again, could be a bent clutch fork, or bent pressure plate)
What all did they replace with the clutch? The whole clutch or just the disc? (the whole clutch would be a kit consisting of a clutch disc, pressure plate, throwout bearing, and a clutch alignment tool)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
