Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 05-17-2007, 03:58 PM
bluecougar bluecougar is offline
Question 95 engine knocking after going through bad puddle
i have a 95 cougar XR7 8 cylinder that died after going through a very bad puddle (more like small pond). the engine light never came on nor did the oil pressure light, however now the car has a very loud knocking sound that speeds up with acceleration. the oil was low after the puddle incident and i want to know what would cause this and if this is going to be a serious problem or something minor that can be lived with. the car seems to run fine other than the noise! please help any info greatly appreciated along with any suggestions on how to quiet the noise!!
Old 05-17-2007, 06:19 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: 95 engine knocking after going through bad puddle
Could have sucked up water into the intake. Water doesnt compress like air does. If water got down into the cylinders, your rods are toast.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-05-2008, 01:44 PM
PJRichardson PJRichardson is offline
your engine is gone.
what were you thinking!!!!!! a small pond!
