Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 05-17-2007, 02:04 PM
leshan leshan is offline
How do we Check and change tansmission fluid for 2006 Malibu LT?
Hi,
I can not find the dipstick in my 2006 Malibu LT.
So, How can we Check and change tansmission fluid for 2006 Malibu LT? Just drop the pan, drain the fluid and replace the filter? If so, How much fluid should we refill?
Thanks.
Old 05-17-2007, 05:38 PM
HyperFox's Avatar
HyperFox HyperFox is offline
Send a message via MSN to HyperFox
Re: How do we Check and change tansmission fluid for 2006 Malibu LT?
Th 3.5L and 2.2L's tansmissions are sealerd for life. There is no dipstick, however there is a check hole on the side of the tramission.
-=Howie=-
2004 Chevy Malibu (Z-Body)
"Experience is a hard teacher because she gives the test first and the lesson afterwards."
Old 05-17-2007, 09:34 PM
Thank you for your reply.
Do you have a picture of the check hole? Is that easy to open?
If I just drop the pan, drain the fluid and replace the filter. How much fluid should I refill?
Old 05-18-2007, 10:15 AM
slls slls is offline
Smile Re: How do we Check and change tansmission fluid for 2006 Malibu LT?
Originally Posted by leshan
Hi,
Thanks.
Start the engine and allow the engine to idle until the transmission fluid temperature has reached the value specified. Depress the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to the PARK range. Raise the vehicle on a hoist. The vehicle must be level, with the engine running and the shift lever in the PARK range. CautionThe engine must be running when the transmission fluid fill plug is removed, or excessive fluid loss will occur. Transmission fluid may be hot. Since the actual fluid level is unknown, stand clear when removing the fill plug. Have a container ready to capture any lost fluid. Do not turn the engine off with the fill plug removed, as you can be injured by hot transmission fluid being expelled out of the oil fill opening.
Remove the transmission plug.
Important
The transmission fluid may darken with normal use and does not always indicate contamination or oxidation.
At least 40°C
Transmission fluid (At least 104°F) 5-10 minutes at idle will give correct temp.
Does the fluid have a burnt odor or a dark brown color?Check the fluid level. The fluid level should be even with the bottom of the threaded plug hole.Is the fluid level low?
Add DEXRON® III automatic transmission fluid in increments of 0.5L until the fluid drains from the plug hole.
Install plug before stopping engine or fluid will spill out of plug hole.
Pan drop and filter change 7.5 qts
Check plug is just to the right of the passenger side axle housing , 11 mm plug, can't miss it, only one there.
Old 05-18-2007, 10:52 AM
Thank you so much. Very clear.
One more question.
Pan drop and filter change 7.5 qts. Does this mean that I even do not need to open the check plug. Just add 7.5 qts after pan drop and filter change?
By the way, my manual says
DEXRON-VI Automatic Transmission Fluid
Automatic Transaxle Complete Overhaul
Automatic Transaxle 4T45-E 6.9 qt
Automatic Transaxle 4T65-E 7.4 qt
I am a little confused.
Old 05-18-2007, 12:50 PM
dpilot83 dpilot83 is offline
The directions by slls were very good. However, I would replace the fluid with the fluid recommended by your owners manual. I have the 99 malibu with the 3.1L engine and mine took exactly 7.4 quarts.
I'm guessing the 65-E is for the 3.5L you have and the 45-E is for the smaller engine.
Anyways if you feel very comfortable that your transmission is in good shape and has never leaked any fluid there is a way you can do it without checking the plug on the side. You must be very careful to catch ALL of your fluid in a totally empty drainpan. Make sure the drain pan is one that would make it easy to transfer the fluid to another container without spilling. Then pour the fluid you drained out into empy quarts from a previous oil change. if it comes out to be 7.4 it's pretty safe to assume you didn't lose any oil and you should be able to put 7.4 back in and not worry about it. However, if it comes out to be anything other than 7.4 you need to do it right. Also, if someone else has changed the oil in the past I wouldn't be too interested in leaving it to chance even if it does come out to 7.4. Honestly, it's really not too terribly hard to do what slls mentioned so I'd recommend doing it anyways, but if you really want to do it another way, that's at least an option.
Old 05-18-2007, 01:48 PM
But the manual says
7.4 qt is Complete Overhaul.
If we just drop the pan and replace the filter. We only have a part of the fluid out. right? So, How much is it?
The best way is use the check hole. But I did not find it on my 2006 malibu LT. Do you have the picture? I used to drop the pan and replace the filter every 30000m for all of my cars. I want to take care of them. But I really do not want to spend $150 at dealer for this. I do not trust them, I would like to do it myself.
Old 05-18-2007, 02:11 PM
I've searched all over and the only info I can find about the 4t65e was unofficial and in another forum.
http://www.automotivehelper.com/topic429545.htm
The second from the last post on this page mentions that a rebuild on a 4t65e is 10 quarts and dropping the pan is 7.4 quarts.
I don't have a picture. My car is the 99 malibu which has a different transmission. I would assume slls is right that the plug is in the same place but I can't verify that. Anyways, if you can't find the plug and your really must do it yourself, the option I mentioned earlier may be your only choice.
Old 05-18-2007, 02:20 PM
Also go to this page directly from Chevy for the Monte Carlo.
http://www.chevrolet.com/montecarlo/specifications/
Click on transmission off to the right side. It says that it has a 4t65e and that it has a 10 quart capacity. With all these things working together I would be inclined to believe that a change is 7.4 quarts and a overhaul is 10 quarts.
Old 05-18-2007, 03:14 PM
Based on your link, I found this, I think my tranny should be 4T45-E
http://www.chevrolet.com/malibu/specifications/
Old 05-19-2007, 11:59 AM
I know about how much mine takes, I still do the plug check. A 4T45E takes 7.5 with pan drop and filter change.
I know you don't want to do the plug check, level, running etc.
If in fact you have a 4T45E 7.5 qts will be ok. If you are not sure what tranny you have, do the plug check, then no mistakes.
Old 05-19-2007, 04:07 PM
Thank you
Old 05-20-2007, 02:43 PM
I think I found check hole. Is it a 11-12mm bolt, aoubt 3-5cm above the pan, in the side of the case, parallel the passenger side axle, face the the passenger tire?
I plan to drop the pan, drain the fluid and replce the filter the first time. And then every 30k miles, I will take the the bolt with engine off. This should drain about half of the fluid out and just refill the same amount.
Thank you all.
Old 05-21-2007, 11:47 AM
Thank you all.
You have found it, you will see when you remove, it has a bullet on end, that way it won't spray out every where.
Old 05-21-2007, 04:11 PM
I just done.
I dropped the pan, drained the fluid, replaced the filter. Totally I refilled with 6.7 qts Amsoil ATF. I did the fluid level check from the check hole. Looks like the manual told us with this way.
Thank you all.
