Old 05-17-2007, 08:24 AM
joeosborne76 joeosborne76 is offline
99 sunfire starting problems
I;m having problems with this car. If you just turn key to start it will crank fine but wont start. Pressing throttle to the floor it will start. It also has a stumble from dead idle but runs great past there. And drives great on the road. Any ideas on this problem? Or could it be the throttle positioning sensor?
Old 05-17-2007, 01:26 PM
noshun's Avatar
noshun noshun is offline
Re: 99 sunfire starting problems
simple one this. Throttle body needs a clean IAC valve is full of gunk.
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 05-19-2007, 04:08 PM
I removed, tested and cleaned the IAC and still does the same thing. I ran a computer code test and it keeps popping up a P0118 fault code. Engine coolant high input.is the sensor bad or does something else send that sensor a signal thats too high. Thanks for any help or suggestions.
Old 05-19-2007, 10:01 PM
Cobraman1024 Cobraman1024 is offline
check for spark at all of your cylinders. if no spark, check electrical connections to the ignition control module. if there is spark, i'd suggest changing out your fuel filter if you haven't done so in awhile.
