Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-17-2007, 07:53 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Differences in turbos
Hey, I finally figured out the difference in the two 50-trims I have.
One was a TC03 From a Saab (900 I b/l). It has an encapsulated carbon seal.
The other turbo is a 50-trim from a Mopar setup.
Here are the measurements on the turbos:
(Both have .42A/R compressor housings. The TC03 has a .63A/R exhaust housing).
(oil cooled: TC03)
Compressor
Ind: 44
Exd: 60
Exhaust
Ind:57.3
Exd:44.93
Wheel height*: 27.35
(Oil/Water cooled: T3)
Compressor
Ind:42.5
Exd:57
Exhaust
Ind:56.96
Exd:48.55
Wheel Height*:27.1
*Exhaust wheel heigh is the reason the exhaust wheel won't sit into the exhaust housing, and why I'm having to swap the shafts too.
Now, I have both housings for the TC03. I only have a compressor housing for the Mopar(unsure of model). I was going to swap the exhaust housings, so that I could run the water cooled turbo. The exhaust wheel on the water cooled turbo won't fit into the exhaust housing.
I want to know what to do... rebuild the TC03, and use it? Find an exhaust housing for the water-cooled and run it? Swap the wheels and run the water cooled(using TC03 wheels)?
Also, anyone have a compressor map for the TC03, or know any specs for it?? (I can post a model # when I get home, for the TC03 only).
Edit: Sorry, my measurements were done with precision calipers, in MM.
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 05-18-2007, 10:34 AM
Mikelb's Avatar
Re: Differences in turbos
Damn, after some searching (thanx for the help guys) I think I've figured it out...
The oil cooled turbo has pretty much all the same specs as this turbo:
http://www.turbobygarrett.com/turbob...R_707160_7.htm
This turbo wouldn't support my goals(400hp at least 350whp), nor be efficient on my car,
According to this map: http://www.turbobygarrett.com/turbob...0_7_comp_e.gif
